How do i work out a flow rate?
In summary, Dominic is looking for help to calculate the flow rate of a fire hydrant in Liters per second, given the pressure of 3.5bar and pipe diameter of 100mm. However, more information is needed for a sensible answer and Dominic is advised to read up on fluid flow. The pressure will most likely drop when the hydrant is opened and selected parts from a previously provided link may also be helpful. A calculator is also recommended for a rough estimate.
Dominic Pew
Hi
I need to work out a flow rate of a fire hydrant in Liters per second.
I know the pressure is 3.5bar and the pipe diameter is 100mm
Any help would be appreciated
Thanks
Hello Dominic, welcome to PF :)
You might need a bit more information to get a sensible answer.
See e.g. this calculator and what it all needs to calculate a pressure drop
My advice would be to read up a bit on fluid flow , e.g. http://udel.edu/~inamdar/EGTE215/Laminar_turbulent.pdf
unfortunately this is all the information i have, i know the pipe is 100mm water main. the outlet in the hydrant is also 100mm and the pressure at this point is 3.5barpsi
Then you need to use your imagination to come up with some more constraints. If the thing is open wide, the 2.5 bar pressure difference with the outside world causes a hefty flow which in turn causes a counteracting pressure drop due to resistance. How much depends on geometry of the pipes.
The 3.5 bar will most likely also drop when it's opened.
Selected parts from this one might be nice too.
And a calculator that needs less input does a calculation for a draining tank. You get the 3.5 bar by filling in 35 m for the height. It comes back with 200 liter/s, spouting out at 26 m/s. As you see further down, it uses the Bernoulli equation and little else. At least its a rough estimate.
[edit] forgot to insert the calculator link. done that now.
for reaching out! Calculating flow rate involves using the equation Q = A x V, where Q is the flow rate in cubic meters per second, A is the cross-sectional area of the pipe in square meters, and V is the velocity of the fluid in meters per second. To convert cubic meters per second to liters per second, you can multiply the result by 1000.
To calculate the cross-sectional area, you can use the formula A = πr^2, where r is the radius of the pipe. In this case, the diameter is given, so you will need to divide it by 2 to get the radius. So, for a pipe with a diameter of 100mm, the radius would be 50mm or 0.05m.
To calculate the velocity, you can use the Bernoulli's equation: P1 + 1/2ρv1^2 + ρgh1 = P2 + 1/2ρv2^2 + ρgh2, where P is pressure, ρ is density, v is velocity, and h is height. In this case, you already know the pressure (3.5bar) and the height (assuming the hydrant is level with the ground). So, you can rearrange the equation to solve for v2, which is the velocity of the fluid at the end of the pipe. Once you have the velocity, you can plug it into the original equation to calculate the flow rate in cubic meters per second.
Remember to convert the result to liters per second by multiplying by 1000. I hope this helps! Let me know if you have any further questions.
FAQ: How do i work out a flow rate?
What is flow rate and why is it important?
Flow rate is the measurement of how much fluid or gas is passing through a specific point in a given amount of time. It is an important concept in fluid dynamics and is used to understand and control the movement of liquids and gases in various systems.
How do I calculate flow rate?
To calculate flow rate, you need to know the volume of fluid or gas passing through a point and the time it takes to pass through that point. You can then use the formula flow rate = volume / time to calculate the flow rate. The resulting unit of measurement will depend on the units used for volume and time.
What factors can affect flow rate?
There are several factors that can affect flow rate, including the size and shape of the opening or pipe, the viscosity of the fluid, the pressure and temperature of the fluid, and the presence of any obstructions or restrictions in the flow path.
How can I increase flow rate?
The flow rate can be increased by increasing the pressure, reducing the viscosity of the fluid, or increasing the size of the opening or pipe. It is also important to minimize any obstructions or restrictions in the flow path to allow for smooth and efficient movement of the fluid.
How is flow rate measured in real-world applications?
In real-world applications, flow rate is often measured using flow meters, which can come in various types such as mechanical, electromagnetic, or ultrasonic. These devices measure the volume of fluid or gas passing through them and provide a continuous reading of the flow rate.
