How Do Local SU(2) Gauge Transformations Affect Field Components?
In summary, SU(2) gauge transformations are essential in local gauge theories as they maintain the symmetry of the theory and describe the interactions between particles. They affect the behavior of particles by determining their properties and interactions with other particles. There are two types of SU(2) gauge transformations - global and local - with the latter being more significant in maintaining symmetry. SU(2) gauge transformations also play a crucial role in the Higgs mechanism, which explains the origin of mass in particles. Additionally, there are other gauge groups, such as SU(3) and U(1), that are used in local gauge theories, along with SU(2), to describe the fundamental interactions in the Standard Model.
Kali_89
Hi all, (Also - if anybody could tell me how to get the latex to work on this page that'd be very handy!)
While not technically homework this is a problem I've found I'm stuck on during my revision. Any help would be greatly appreciated.
"By demanding that the covariant derivative [itex] D^\mu \Psi [\latex] transforms in the same way as the fundamental doublet [itex] \Psi [\latex] under a local SU(2) gauge transformation, derive how the field components [itex] W_{\mu}^{i}, (i=1,2,3), [\latex] transforms under an infinitesimal such transformation. The Pauli matrix identity [ latex ] (\underline{\sigma} \cdot \underline{a})(\underline{\sigma} \cdot{b}) = \underline{a} \cdot \underline{b} + i \underline{\sigma} \cdot (\underline{a} \times \underline{b}) [\latex], may be assumed."
I think that the following equations are going to have to be used:
[itex] \begin{align}
D_{\mu} &= \partial_{\mu} + igW_{\mu}^{a} t^{a}, \\
[t_{a},t_{b}] &= i C_{abc}t_{c}, \\
\end{align} [\latex]
where [itex] D_{\mu} [\latex] is the modified derivative, g is our coupling constant, W is the field in question, t are the generator matrices and C is the structure constant.
Given that the covariant derivative transforms in the same way as the doublet I know we can write [itex] D_{\mu} \psi ----> D'_{\mu} \psi' = U(\underline{x}) (D_{\mu} \psi ) [\latex]. From this we can easily write [itex] D'_{\mu} [\latex]. I've found in my notes a general expression for U (incidentally, what is U? I see it has the same sort of form as the phase for transformations I've seen) as [itex] U(x) = \exp{(-ig\sum_{1}^{n^2 - 1} t_{k} \alpha_{k})} [\latex] where the n = 2 for the case of SU(2). Here I believe [itex] \alpha [\latex] is the phase but I'm not at all sure. The generators for SU(2) are half the Pauli matrices.
Now, using that we're taking an infinitesimal transformation we can Taylor expand U and so find that [itex] U(x) = I - igt_{k} \alpha_{k} [\latex]. At this point I've substituted most of the equations I've got together in order to try and find the following equation which I believe to be the final answer:
[itex] W'_{\mu}^{a} = W_{\mu}^{a} - \frac{1}{g} \partial_{\mu} \alpha_{a} - C_{abc} W_{\mu}^{c}. [\latex]
Substituting in I do seem to make some sort of headway but I've not really understood what I've been doing and also how to treat terms like [itex] \partial_{\mu} (\alpha_{a} t_{a} \psi) [\latex].
Hi, use [tex]\text{[tex]}[/tex] or [itex]\text{[itex]}[/itex]
1. Homework Statement
"By demanding that the covariant derivative [tex] D^\mu \Psi [/itex] transforms in the same way as the fundamental doublet [tex] \Psi [/tex] under a local SU(2) gauge transformation, derive how the field components [tex] W_{\mu}^{i}, (i=1,2,3), [/tex] transforms under an infinitesimal such transformation. The Pauli matrix identity [tex] (\underline{\sigma} \cdot \underline{a})(\underline{\sigma} \cdot{b}) = \underline{a} \cdot \underline{b} + i \underline{\sigma} \cdot (\underline{a} \times \underline{b}) [/tex], may be assumed."
2. Homework Equations
[tex] \begin{align}
\end{align} [/tex]
where [tex] D_{\mu} [/tex] is the modified derivative, g is our coupling constant, W is the field in question, t are the generator matrices and C is the structure constant.3. The Attempt at a Solution
Given that the covariant derivative transforms in the same way as the doublet I know we can write [tex] D_{\mu} \psi ----> D'_{\mu} \psi' = U(\underline{x}) (D_{\mu} \psi ) [/tex]. From this we can easily write [tex] D'_{\mu} [/tex]. I've found in my notes a general expression for U (incidentally, what is U? I see it has the same sort of form as the phase for transformations I've seen) as [tex] U(x) = \exp{(-ig\sum_{1}^{n^2 - 1} t_{k} \alpha_{k})}[/tex] where the n = 2 for the case of SU(2). Here I believe [tex] \alpha [/tex] is the phase but I'm not at all sure. The generators for SU(2) are half the Pauli matrices.
Now, using that we're taking an infinitesimal transformation we can Taylor expand U and so find that [tex] U(x) = I - igt_{k} \alpha_{k} [/tex]. At this point I've substituted most of the equations I've got together in order to try and find the following equation which I believe to be the final answer:
[tex] W'_{\mu}^{a} = W_{\mu}^{a} - \frac{1}{g} \partial_{\mu} \alpha_{a} - C_{abc} W_{\mu}^{c}. [/tex]
Substituting in I do seem to make some sort of headway but I've not really understood what I've been doing and also how to treat terms like [tex] \partial_{\mu} (\alpha_{a} t_{a} \psi) [/tex].
You'll want to write down the expression for the infinitesimal variation [tex]\delta (D_\mu\psi)^a[/tex], expressing it in terms of [tex]\delta \psi^a[/tex] (which you know) and [tex] \delta W_\mu^a[/tex], which you're trying to determine.
That's close, but you can see that you have an extra free index on the [tex]CW[/tex] term that isn't on the LHS, so that term is wrong.
You can expand that term out using the product rule for derivatives. It also might help to put the matrix indices on the [tex](t^a)_{bc}[/tex] and the index on [tex]\psi^a[/tex].
As a scientist, it is important to carefully understand the concepts and equations involved in a problem before attempting to solve it. In this case, it seems that you are on the right track but may need some clarification on a few key points.
Firstly, U(x) is the gauge transformation matrix, which represents the change in the field under a gauge transformation. It is a function of the spacetime coordinates x and the transformation parameters α. The generators t_k are the matrices that generate the group transformations, and in the case of SU(2), they are the Pauli matrices.
Next, the covariant derivative D_μ is defined as the ordinary derivative plus a term involving the gauge field W_μ. In order for the covariant derivative to transform in the same way as the fundamental doublet, the gauge field must transform in a specific way. This is what you are trying to derive in this problem.
To solve this problem, you will need to use the Taylor expansion of the gauge transformation matrix U(x) and the commutation relations for the generators t_k. You will also need to use the Pauli matrix identity given in the problem statement. Remember that the generators t_k are matrices, so when taking derivatives with respect to the transformation parameters α, they will need to be treated as such.
Finally, when substituting and simplifying, be careful to keep track of the indices on the generators and gauge fields. This will help you to correctly identify the transformation rule for the gauge field.
I hope this helps to clarify some of the key points in this problem. It is important to carefully understand the concepts and equations involved in order to successfully solve it. Good luck with your revision!
FAQ: How Do Local SU(2) Gauge Transformations Affect Field Components?
What is the significance of SU(2) gauge transformations in local gauge theories?
SU(2) gauge transformations are a fundamental component of local gauge theories, which are used to describe the interactions between particles in the Standard Model of particle physics. These transformations are based on the special unitary group SU(2), which is a mathematical group that describes the symmetry of certain physical systems. In local gauge theories, SU(2) gauge transformations play a crucial role in maintaining the symmetry of the theory as well as in the formulation of the fundamental interactions.
How do SU(2) gauge transformations affect the behavior of particles?
SU(2) gauge transformations are associated with the exchange of force-carrying particles, known as gauge bosons, between particles with a certain property, such as electric charge or weak isospin. These transformations are responsible for the interactions between particles, such as the strong nuclear force between quarks and the weak nuclear force between leptons. The behavior of particles is affected by these interactions, which determine their properties and behavior in various physical processes.
What is the difference between global and local SU(2) gauge transformations?
Global SU(2) gauge transformations involve the same transformation being applied to all points in space and time, while local SU(2) gauge transformations vary at different points in space and time. In other words, global transformations are uniform throughout the entire system, while local transformations can change from point to point. In local gauge theories, local SU(2) gauge transformations are essential for maintaining the symmetry of the theory, while global transformations do not have the same significance.
How are SU(2) gauge transformations related to the Higgs mechanism?
The Higgs mechanism is a key concept in the Standard Model that explains the origin of mass in particles. In this mechanism, the Higgs field interacts with particles and gives them mass through a process known as spontaneous symmetry breaking. SU(2) gauge transformations play a crucial role in the Higgs mechanism, as they allow for the Higgs field to interact with particles and give them mass while preserving the symmetry of the theory.
Are there other gauge groups besides SU(2) that are used in local gauge theories?
Yes, there are several other gauge groups that are used in local gauge theories, such as SU(3), which describes the strong nuclear force, and U(1), which describes the electromagnetic force. These groups, along with SU(2), make up the three fundamental interactions in the Standard Model. Other gauge groups, such as SO(10) and E(6), have also been proposed in various extensions of the Standard Model.
