B How do mathematicians come up with new proofs?
  • B
  • Thread starter Thread starter docnet
    Proofs
Mathematicians often arrive at new proofs through a combination of deep prior knowledge and intense focus on a problem, as illustrated by Yitang Zhang's experience with bounded gaps between primes. While the final proof may appear to be a product of individual genius, it typically builds upon extensive prior research and discussions with peers. The process involves numerous intricate steps that may not seem connected at first, but each contributes to the overall logic leading to the conclusion. Insights can emerge suddenly after prolonged contemplation, but the detailed work required to formalize these ideas is substantial. Ultimately, the journey to a proof is a blend of inspiration and rigorous effort, reflecting the complexity of mathematical discovery.
docnet
TL;DR Summary
How are research-level proofs written?
I watched an interview of Yitang Zhang and he said "the way to prove a finite limit of bounded gaps between primes came to him during ##30## minutes in an afternoon", and he worked alone and did not collaborate with others during his research time.
After looking up the proof, I am in disbelief he worked alone. What baffles is how one person could write ##50## pages of what feels like an enormously complicated and difficult mathematical maze to end up with the final result "so and so is the lower limit of so and so". I can't believe that so much work is done just to prove the final result because so many independent steps are taken, that don't seem to be obviously connected to the final result at all. But every step is nit-picky, deliberate, and brings the logic one step closer to the desired result. Are there mathematicians who could even read the entire proof and understand everything in it?
My main question is, do research-level proofs in mathematics such as "bounded gaps between primes", or "Harnack's Inequality for the Ricci Flow" or "Every simply connected, closed 3-manifold is homeomorphic to the 3-sphere." really come as a result of a one-person's genius, like everyone makes them out to be?
Mathematics news on Phys.org
The key ideas of a proof can be summarized much shorter than the fully worked-out proof. You can give a mathematician working in that field a one-page summary (or maybe even shorter) and they'll be able to reproduce the proof based on that summary.
At the time of the "30 minutes in an afternoon", Zhang had already spent quite some time working on that problem and related problems. He had some preliminary results, he was obviously aware of the older results by his colleagues, had discussed the problem with them many times and so on. At the end of these 30 minutes he didn't have the 50 pages of proof written down, but he had an idea how to combine all these things, plus a few things he expected to be able to proof later, in a way that would lead to a proof.
Likes suremarc, Vanadium 50 and berkeman
If one thinks hard and continuously about something for a long time, it seems that the mind works on its own unconsciously. Ideas just pop up seemingly out of nowhere. One "sees" the relationship. However working out the details may take a huge amount of work.
Likes DaTario, weirdoguy, docnet and 3 others
I'm not a "working scientist" example, but I had numerous situations, where the solution to a problem simply came to me during a... dream.
weirdoguy said:
during a... dream.
In a jacuzzi for me...
(but as pointed out before, I'd put in hundreds of hours on that problem before the final aha moment)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
