How do motors on gimbals work? (2-axis camera mount application)
In summary: Another option would be to buy a pre-made gimbal system, which would be the best option if you already know what you want.
emdezla
Hello everyone,
I am trying to build a 2-axis camera gimbal, which will control yaw and pitch. I have bought sensorless BLDC motors (GB280870KV) which I drive using SPWM. For knowing the camera orientation, I am using IMU sensors (accelerometer, gyroscope, and magnetometer) integrated on the microcontroller board (STM32F3DISCOVERY).
So now my problem comes on how to implement a controller. I don't know how real gimbals work: do motors use a position control strategy or a speed control strategy? In other words, should my motors stop working when the ideal position is reached or should they continue to work at super loooow speeds?
Thank you very much for your answers.
is this for a security camera or something else ?
that's a serious overkill for a security camera, those things are not needed to be known as the camera operator can see where the camera is pointing.
It would only be needed if the camera was fully self controlling
usually position control
that depends on what you are trying to achieve ... no point in it continuing to move past whatever you are wanting the camera to look at
So, maybe some info on what you are actually trying to achieve with this projectDave
Um, IMHO, you could cut a LOT of grief by using modelling / robotic servo motors, which have all the feedback / dead-zone / approach stuff built in...
usually position controlthat depends on what you are trying to achieve ... no point in it continuing to move past whatever you are wanting the camera to look at
What I am trying to achieve is a stabilized platform for a camera. This platform will be placed on top of a boat and will have to compensate for the boat movements in order to point always in the right direction. The final aim of this project is actually to record boat races so the "right direction" at which the camera should point is the finish line
I would say a sensorless BLDC driver is likely not going to work very well for you, they need a certain amount of motor speed to detect the back EMF to then determine what rotor sector its into then be able to control the machine, basically they don't work too cleanly if the machine is not above some speed. I imagine in your case you'd like it to probably know this location if its not turning and maybe provide some zero speed torque (ie holding position), so you'll want a motor controller that uses a rotor position sensor.
Likes emdezla
OK great ... that was the sort of info we all needed right at the start :smile:
OK, there are already a couple of gimbal systems out there that I am personally aware of.
One where a standard camera eg a DSLR can be mounted into and they give aweome stabilisation
I have always wanted one of them
The other is like those used in drones ... my Parrot drone has a wonderful 3 axis gimbal system in it, keeps the video really stable
It would probably be a great idea to look into what either of those systems are doing/usingEDIT: Ohhh and I think you will probably find you need a 3 axis one ... boats don't move in just 2 directions
Dave
Likes jrmichler
As @davenn pointed out, his Parrot drone has a stabilized camera. Most likely the fastest and cheapest way is to get one of those systems and modify as needed.
Likes davenn
Related to How do motors on gimbals work? (2-axis camera mount application)
1. How does a gimbal stabilize a camera?
A gimbal uses motors to counteract any movement or vibrations of the camera. The motors are controlled by sensors that detect the camera's position and make adjustments accordingly to keep it stable.
2. What are the two axes of movement in a gimbal?
The two axes of movement in a gimbal are pitch and roll. Pitch refers to the up and down movement of the camera, while roll refers to the side to side movement.
3. How do the motors on a gimbal work?
The motors on a gimbal use a feedback control system to adjust the position of the camera. They receive signals from the sensors and make precise movements to keep the camera stable.
4. What type of motors are used in gimbals?
There are various types of motors that can be used in gimbals, including brushless DC motors, stepper motors, and servo motors. These motors are chosen based on their torque, speed, and accuracy.
5. Can gimbals be used for other applications besides camera stabilization?
Yes, gimbals can be used for a variety of applications, such as in drones, robotic arms, and even in the film industry for stabilizing lights and other equipment. They are also used in virtual reality systems to provide a more immersive experience.
  • Electrical Engineering
14K
  • Mechanical Engineering
  • General Math
  • Aerospace Engineering
