How do O2 molecules from solution get into ATP?
  • Thread starter Kuzon
  • Tags
    Molecules
In summary, water hydrolyzes ATP, releasing a phosphate molecule. That phosphate will contain an 18O atom and the now ADP molecule takes an H atom from the H218O. There must be a free H.
Kuzon
42
This was a practice exam Q:
ATP is added to the myosin ATPase domain in water labeled with an oxygen isotope. After 50% of the ATP has been hydrolyzed, the remaining ATP is isolated and found to contain 18O. Explain.
I get how H2O is used in order to regenerate ATP from the Pi and ADP, but on all the diagrams I've seen online I can't see where the oxygen from that H2O goes.
Biology news on Phys.org
I assume that the water is H218O (18O being the isotope of O with atomic mass 18). The water hydrolyses the ATP releasing a phosphate molecule. That phosphate will contain an 18O atom and the now ADP molecule takes an H atom from the H218O. There must be a free H.
AM
AM
I don't really understand the explanation. How can water hydrolyse the ATP when hydrolysis is a reaction... It's not like water is a catalyst?
The bond strength between the outer phosphates in the ATP is weak because of the strain due to strong repulsion forces between them. That strain is enough so that the bonds can be broken by hydrogen bonding with water molecules. ATPase enzymes act as a catalyst. There is a great deal of energy released once the bonds are broken because of large the repulsive coulomb forces between these phosphates.
AM
The actual mechanism by which ATP hydrolysis occurs is the subject of this paper, which you may find interesting.
AM
I'm sorry I saw this thread so late. I think that reference, part of vast, important and fascinating story or stories may be too complicated and specialised for the general question and principle here.
What is happening is this: O18 labelled water attacks the enzyme-bound ATP creating enzyme-bound ADP and enzyme-bound O18-labelled Pi. While bound to the enzyme, this reaction is reversible. If it were reversed exactly, then the same labelled oxygen atom that had been Incprporated would be expelled of course. But all four O atoms of Pi are chemically equivalent. The enzyme-bound phosphate ion can rotate while sitting in the enzyme, and so the oxygen atom expelled in the reverse reaction will often be not the same one as entered and thus the ATP is reconstituted containing O18.
FAQ: How do O2 molecules from solution get into ATP?
1. How do O2 molecules enter the cell to be used in ATP production?
O2 molecules enter the cell through a process called diffusion. They move from an area of high concentration (such as the air or water) to an area of lower concentration (inside the cell) through small openings in the cell membrane called pores.
2. What happens to O2 molecules once they enter the cell?
Once O2 molecules enter the cell, they bind to hemoglobin proteins in red blood cells and are transported to the mitochondria, the powerhouse of the cell. Here, they are used in the process of cellular respiration to produce ATP, the main source of energy for the cell.
3. How do O2 molecules from solution get into the mitochondria?
O2 molecules from the solution in the cell diffuse through the mitochondrial membrane, which is specifically designed to allow the passage of small molecules such as oxygen. Once inside the mitochondria, the O2 molecules can be used in the production of ATP.
4. Can O2 molecules get into ATP without entering the mitochondria?
No, O2 molecules must enter the mitochondria in order to be used in ATP production. The mitochondria contain all the necessary enzymes and proteins for the process of cellular respiration, which uses O2 to produce ATP. Without the mitochondria, O2 molecules would not be able to contribute to ATP production.
5. How do O2 molecules from solution contribute to ATP production?
O2 molecules are essential for the production of ATP through cellular respiration. In this process, O2 molecules act as the final acceptor of electrons, which are released from glucose molecules. As the electrons are passed through a series of reactions, they generate a proton gradient that is used to produce ATP. Without O2, this process cannot occur and ATP cannot be produced.
