How Do Orbiting Black Holes Generate Gravitational Waves?
In summary, gravitational waves can be generated by a system with a time-varying quadrupole moment of energy-momentum, similar to how electromagnetic waves are generated by a system with a time-varying dipole moment of charge. Even a single event without oscillations can produce gravitational waves of various frequencies, which can be dampened or amplified in the system. It is similar to how two charges doing the same movement can produce electromagnetic waves, even when the center of charge is not moving. The cancellation of waves in the system can be shown by analyzing the frequencies and reactions of the system.
jnorman
316
I am probably missing something, but it seems to me that the only way gravitational waves could be generated would be if the center of gravity of a massive body or system began oscillating somehow. The detection of such waves was recently reported and were supposedly generated by a pair of black holes orbiting each other. I do not understand how this system could generate gravitational waves when the center of gravity of the system is not moving/oscillating. Help? Thanks.
Do you understand how two charges doing the same movement would produce EM-waves, even when the center of charge is not moving?
As I recall, for gravitational waves the source needs to have a time-varying quadrupole moment (of energy-momentum) whereas for electromagnetic waves the source needs to have only a time-varying dipole moment (of charge).
A single step function (a step function f(t)=0 when t<0; f(t)=1 when t>0) contains all frequencies. So a single event, even without oscillations, can generate all frequencies. Then the system will react to the frequencies differently. It will damp out some frequencies and will oscillate to other frequencies. Sort of like a single push on a suspended weight will make it swing in a cyclic fashion.
How do you show that the waves don't cancel each other out?
Related to How Do Orbiting Black Holes Generate Gravitational Waves?
1. What are gravity waves and why are they important?
Gravity waves are a type of disturbance in the fabric of space-time, predicted by Einstein's theory of general relativity. They are important because they provide us with valuable information about the universe and can help us understand the behavior of massive objects such as black holes and neutron stars.
2. How are gravity waves detected?
Gravity waves are detected using highly sensitive instruments called interferometers. These instruments use lasers to measure tiny changes in the distance between two mirrors caused by the passing of a gravity wave.
3. Why is gravity wave detection confusing?
Gravity wave detection can be confusing because the signals are extremely faint and can be easily masked by other sources of noise. Additionally, the analysis of data collected by interferometers can be complex and require advanced mathematical techniques.
4. What challenges do scientists face in detecting gravity waves?
One of the biggest challenges in detecting gravity waves is eliminating sources of noise that can interfere with the signals. This requires careful calibration and testing of the instruments. Another challenge is developing algorithms and techniques to accurately analyze the data and distinguish gravity wave signals from other sources.
5. How can the detection of gravity waves benefit us?
The detection of gravity waves not only helps us understand the universe and its origins, but it also has practical applications. For example, gravity wave detectors can be used to study earthquakes and other natural disasters, as well as to improve technologies such as GPS and atomic clocks.
