How do Shifts Affect Invertible Functions?
  • MHB
  • Thread starter renyikouniao
  • Tags
    Functions
In summary: I have for now!In summary, adding a constant to a function does not affect its monotonicity. The range of g(x) also is (0,infinity) .
renyikouniao
41
Show that if f(x) is an invertible function then g(x)=f(x)+c is an invertible function.If f^(-1) is known what is g^(-1)
Thank you in advance
a) Does adding a constant to a function affect its monotonicity?
b) What effect does the constant have on the range of $g(x)$, and hence on the domain of $g^{-1}(x)$?
No,it doesn't
I have no idea on this part
Suppose we have the monotonic function:
\(\displaystyle f(x)=e^x\)
We know its range is \(\displaystyle (0,\infty)\).
So, what is the range then of:
\(\displaystyle g(x)=f(x)+c\)
What relationship exists between the range of a function and the domain of its inverse?
The range of f(x) is the domain of g(x),the domain of g(x) is the range of f(x)?
Adding a constant to a function has the effect of shifting it vertically, thereby affecting its range. The range of $g(x)=e^x+c$ is therefore $(c,\infty)$. So then what would the domain of $g^{-1}(x)$ be, and how do we shift the domain of a function?
the domain of $g^{-1}(x)$ would be $(c,\infty)$
Correct, so how would we shift the domain? How do we shift a function horizontally?
shift c units horizontally?
Yes, how would we shift a function $c$ units to the right?
I don't get this...
Suppose $f(x)$ has a root at $x=c$, or $f(c)=0$. Then $f(x-h)$ will have a root at $x-h=c$, or $x=c+h$. Hence, $f(x-h)$ is the graph of $f(x)$ shifted $h$ units to the right. So how can we apply this to the original problem?
So..the original function has domain:c,infinity. range:0,h
the inverse function has domain:0,h. range:c,infinity
Let's go back to the original question...
a) We are given that $f(x)$ is an invertible function, and then we are asked to then show that $g(x)=f(x)+c$ is also invertible.
While we have observed that adding a constant to a function does not affect its monotonicity, how can we explain/demonstrate this mathematically?
b) We are asked to give $g^{-1}(x)$ in terms of the known $f^{-1}(x)$.
We have observed that the graph of $g(x)$ is shifted vertically from that of $f(x)$, hence the graph of $g^{-1}(x)$ must be horizontal shifted (by the same amount) from that of $f^{-1}(x)$. So how can we state this mathematically?
It should be noted that f(x) is not requested to be continous, so that monotonicity is not a necessary condition for f(x) to be invertible. For example the function...
$$f(x)=\begin{cases} -2 - x \ \text{if}\ -1< x < 0\\ 0\ \text{if}\ x=0\\ 1 + x\ \text{if}\ 0< x< 1 \end{cases}\ (1)$$
... is invertible even if not monotic... Kind regards $\chi$ $\sigma$
Another example: $$f(x)=\begin{cases} x &\mbox{if}& x\not\in\{0,1\}\\ 0& \text{if}& x=1\\ 1 & \text{if}& x=0 \end{cases}\Rightarrow \exists f^{-1}\;\wedge\;f^{-1}=f$$
First, some metamathematical remarks. I admire Mark's patience in explaining the effect of adding a constant on the range of a function, but I find the whole first page hard to follow.
I am not sure it is necessary to talk about the relationship between the domains of $f^{-1}$ and $g^{-1}$ because if the domain of some function $u$ is $D$ and the domain of some $v$ is $\{x+c\mid x\in D\}$, it obviously does not follow that $v(x)=u(x-c)$.
I am not sure it is helpful to talk about graph shifting, either. I am pretty sure that if the OP did not know how adding a constant changes the range, s/he would be lost by the fact quoted above. Horizontal graph shifting is counterintuitive because adding a positive constant to the argument leads to the graph's shift to the left rather than to the right.
And it has been pointed out that instead of monotonicity of $g(x)$ we must show its injectivity.
I think it is much easier to focus on algebra involving concrete numbers $x$ and $y$ instead of talking about domains or graphs as a whole.
So, we have $g(x)=f(x)+c$ and we need to find $g^{-1}$. This means we need to solve the equation $f(x)+c=y$ for $x$. It is solved in the usual way: we look at operations applied to $x$ in the left-hand side and reverse them. There are two operations applied to $x$: first $f$ and then adding $c$. Therefore, we first have to subtract $c$ from both sides to neutralize addition, and then ... (use the fact that $f^{-1}$ is known).
All I was trying to impart is that if the graph of $f(x)$ is shifted up $c$ units to get $g(x)$, then the graph of $f^{-1}(x)$ will be shifted to the right by $c$ units to get $g^{-1}(x)$. This immediately leads to the result we find from the algebraic approach.
FAQ: How do Shifts Affect Invertible Functions?
What is an invertible function?
An invertible function is a mathematical function that has a unique inverse function. This means that for every input value, there is a unique output value and for every output value, there is a unique input value. In other words, the function can be reversed or "inverted" to get back to the original input value.
How can I determine if a function is invertible?
A function is invertible if it passes the horizontal line test. This means that if a horizontal line is drawn anywhere on the graph of the function, it should intersect the graph at most once. If a function fails the horizontal line test, it is not invertible.
What is the notation for an inverse function?
The notation for an inverse function is f-1(x). This indicates that it is the inverse function of f(x). It is important to note that this notation does not mean the reciprocal of f(x), but rather the inverse.
Can all functions be inverted?
No, not all functions can be inverted. For a function to be invertible, it must be both one-to-one and onto. This means that each input must have a unique output and each output must have at least one corresponding input. If a function is not one-to-one or onto, it cannot be inverted.
How can inverse functions be used in real life?
Inverse functions have many practical applications in fields such as physics, engineering, and economics. For example, in physics, inverse functions can be used to calculate the position of an object at a specific time based on its velocity function. In economics, inverse functions can be used to find the optimal price for a product to maximize profit. In general, inverse functions are useful for solving equations and understanding the relationship between variables in real-life situations.
