How Do Spherical Harmonic Tensors Behave Under the Laplacian Operator?
Compared to other methods for obtaining the coefficients, the method used here is not as efficient since it requires the use of the tangential derivative. However, it does provide a clear and direct way of obtaining the coefficients. In summary, the conversation discusses the use of a tangential derivative to obtain the coefficients for a symmetric traceless tensor of rank l, which are then used to show that the Laplacian of a spherical harmonic is equal to -l(l+1) times the original spherical harmonic. The discussion also touches on the position-independence of the tensor coefficients for spherical harmonics.
latentcorpse
1,444
Let [itex]C_{i_1i_2 \dots i_l}[/itex] be a symmetric traceless tensor of rank [itex]l[/itex]. Let [itex]\hat{x}= \frac{x}{|x|}[/itex] be a three dimensional unit vector on the unit sphere. Define a tangential derivative such that [itex]\nabla_i \hat{x_j} = \delta_{ij} - \hat{x_i} \hat{x_j}[/itex]. For the spherical harmonic [itex]Y_l(\hat{x})=C_{i_1i_2 \dots i_l} \hat{x_{i_1}} \hat{x_{i_2}} \dots \hat{x_{i_l}}[/itex] show that
[itex]\nabla^2 Y_l( \hat{x} ) = -l(l+1) Y_l( \hat{x})[/itex]
I'm not really getting anywhere here as I can't see how the [itex]\nabla^2[/itex] moves through the tensor so that i can act it on the x's.
Try this:
[tex]\nabla^2 Y_l(\hat{x}) = \delta^{mn}\nabla_m[\nabla_n Y_l(\hat{x})][/tex]
I'm not sure if you can consider the tensor coefficients [itex]C_{i_1 i_2\cdots i_l}[/itex] to be position-independent, i.e. to have the property
[tex]\nabla_m C_{i_1 i_2\cdots i_l} = 0[/tex]
diazona said:
Try this:
They're spherical harmonics, so the [itex]C_{i_1 i_2\cdots i_l}[/itex] are indeed constants. The coefficients for low orders can be deduced from the table at http://en.wikipedia.org/wiki/Table_of_spherical_harmonics
FAQ: How Do Spherical Harmonic Tensors Behave Under the Laplacian Operator?
What are spherical harmonic tensors?
Spherical harmonic tensors are mathematical objects used to describe the shape and orientation of a three-dimensional object. They are made up of spherical harmonics, which are mathematical functions that describe the distribution of energy in a spherical system.
How are spherical harmonic tensors used in science?
Spherical harmonic tensors are used in many areas of science, including physics, chemistry, and geology. They can be used to describe the shape of molecules, the orientation of crystals, and the distribution of magnetic fields, among other things.
3. What is the difference between spherical harmonics and spherical harmonic tensors?
Spherical harmonics are mathematical functions that describe the distribution of energy in a spherical system, while spherical harmonic tensors are mathematical objects made up of spherical harmonics that are used to describe the shape and orientation of a three-dimensional object.
4. How are spherical harmonic tensors related to spherical coordinates?
Spherical harmonic tensors are closely related to spherical coordinates, which are a system of coordinates used to describe points in three-dimensional space. The spherical harmonic tensors are used to describe the shape and orientation of objects in spherical coordinates.
5. Are spherical harmonic tensors used in any practical applications?
Yes, spherical harmonic tensors are used in various practical applications, such as in geophysics to model the Earth's magnetic field and in crystallography to determine the orientation of crystals. They are also used in image processing and computer graphics to analyze and manipulate three-dimensional objects.
29K
27K
