How Do Steam Plants Use Different Fuels?
In summary: Historically it wasn't uncommon for boilers to be run on fuels different from those they were originally designed for. Ships were commonly converted from coal to petroleum after the 1910s, and for a period of time it was common to convert power plants from coal to petroleum as well. A common feature then and now is the use of petroleum to help start coal fired power plants or improve their burning of coal. After the energy crises of the 1970s and the increased cost of petroleum many power plants were converted to coal, including some that were originally designed to burn petroleum. Some steam plants were built to run on natural gas as well.
Delta Force
81
I haven't been able to find a diagram of anything other than a coal fired steam plant and I haven't been able to find any information on what exactly is done to change a power plant between fuel types. Does anyone know what kind of modifications are done to allow the different fuel types to be burned? Are there any diagrams of steam plants in different configurations?
Oil to gas is easy; you just change the burner. It's basically just a flamethrower that bolts over a hole at the bottom of the boiler.
Coal to oil would be more complicated because of how much space a burning bed of coal takes up.
I can't say that I've seen conversion project plans, but I think I can outline the steps.
  1. Add fuel handling to bring the fuel to the furnace. Coal pulverizers can be eliminated.
  2. Add burners of appropriate size (this is what @russ_watters mentioned. (By the way, coal is blown into the furnaces as a fine dust, not burned in beds.) Also, igniters need to be appropriate.
  3. Each burner must be dynamically adjustable to match the original proportions of heat to furnace/superheater/reheater sections.
  4. Weld shut the wet bottom of the furnace (where coal slag was removed).
  5. Adjust the primary and secondary air fans to provide enough air without wasting fan power.
  6. Remove/bypass the bag house and precipitators from the exhaust end used to catch flyash from coal.
  7. Re-calibrate and re-tune the boiler control systems.
  8. Re-design safety and startup/shutdown logic.
  9. Evaluate safety contingencies.
  10. Re-program the training simulator (if any) and retrain the operators.
In some cases, like in the NYC area, they are required to fuel with oil or gas with rapid switching between fuels. That means dual fuel systems.
Edit: add re-design control room panels.
Likes jim hardy
And coal requires pulverizers and fans to blow the dust into the boiler. Totally different fuel handling than oil or gas which are pumped in pipes right to their respective burners.
Our fossil units burned oil or natural gas (when we could get it) or a mix. We didn't have coal in Florida.
The analog pneumatic control system controlled the flows of both fuels into the burners, and positions of dampers inside the boiler. Gas with its blue flame has less radiant heat than oil's yellow-orange flame so the gas gets routed a little differently through the superheaters.. .[/QUOTE]
Related to How Do Steam Plants Use Different Fuels?
1. How do steam plants use different fuels?
Steam plants use different fuels by burning them in a furnace to heat water and produce steam. The steam then turns turbines, which generate electricity.
2. What types of fuels can steam plants use?
Steam plants can use a variety of fuels, including coal, natural gas, oil, biomass, and nuclear fuel.
3. How does the type of fuel affect the efficiency of a steam plant?
The type of fuel used can greatly impact the efficiency of a steam plant. For example, coal-fired plants tend to have lower efficiency due to the lower energy content of coal compared to natural gas. However, this can be offset by using more advanced technology and equipment.
4. Can steam plants use renewable energy sources?
Yes, steam plants can use renewable energy sources such as biomass and geothermal energy. These sources are becoming increasingly popular as the world moves towards more sustainable energy options.
5. What are the environmental impacts of using different fuels in steam plants?
The environmental impacts of using different fuels in steam plants can vary greatly. Fossil fuels such as coal and oil can contribute to air and water pollution, while renewable energy sources have lower emissions and a smaller environmental footprint. However, all steam plants must adhere to strict regulations to minimize their impact on the environment.
  • Mechanical Engineering
  • Electrical Engineering
