How do supersonic sources create sonic booms?
In summary: So as the sides of the cones close in on the source, they will continue to add up, creating a sonic boom.
shadowzoid
Why do supersonic waves (when the source is faster than the wave) create sonic booms? I understand that when a source breaks the sound barrier and travels at the speed of its waves, the waves just build up at the front of the source and create a condensed sound of multiply sound waves added together, creating a sonic boom. Yet, when a source is faster than the waves, there is no buildup of waves because a new wave is created in front of the last and goes the same velocity as it so it wouldn't catch up. How do these sources create sonic booms?
http://physics.info/shock/doppler-shock-4.html
see, they don't overlap
Correct.
Well...
Well then what is the dark line on the edge of that wedge-shape they form? It's still a shock wave. All that has happened between that image and this one ( http://physics.info/shock/doppler-shock-3.html ) is the angle of the two shock waves has move back/closed from perpendicular to the direction of motion. It isn't like the sound waves for a Mach 1 shock wave stay in one place: they are still propagating out away from the source along the shock wave.
You must consider not only the "front end" of the cone, but also the sides. For speed faster than the speed of sound, the sides of those circles still add up.
Remember, sound travels in all directions, not just forward.
FAQ: How do supersonic sources create sonic booms?
What is a sonic boom and how is it created?
A sonic boom is a loud explosive sound caused by an object moving faster than the speed of sound. It is created when an object, such as an aircraft, travels through the air faster than the speed of sound, creating a shockwave of compressed air that produces the loud noise.
How does the speed of sound affect the creation of a sonic boom?
The speed of sound plays a crucial role in the creation of a sonic boom. When an object travels at the speed of sound, the sound waves it produces travel at the same speed, causing them to pile up and create a loud, explosive sound. As the object continues to accelerate and surpass the speed of sound, the sound waves continue to pile up and create a continuous loud noise.
What types of objects can create sonic booms?
Any object that travels faster than the speed of sound can create a sonic boom. This includes aircraft, rockets, and even bullets. However, the size and shape of the object, as well as the surrounding atmospheric conditions, can also affect the intensity and characteristics of the sonic boom.
Can sonic booms be harmful to humans or the environment?
Sonic booms can be harmful to humans and the environment if they occur at ground level. The loud noise can cause damage to buildings and disrupt wildlife. However, at high altitudes, sonic booms are not as harmful since the sound waves have more space to dissipate. Additionally, strict regulations are in place to ensure that supersonic flights are only permitted over unpopulated areas.
Is there any way to reduce or eliminate sonic booms?
Several studies and experiments are being conducted to reduce or eliminate the loud noise caused by sonic booms. One approach is to design aircraft with more aerodynamic shapes that can reduce the intensity of the shockwave. Another approach is to fly at higher altitudes, where the sound waves can dissipate more easily. Additionally, NASA is researching the development of a supersonic aircraft that can create a soft thump instead of a loud boom.
16K
9K
16K
