How do the appliances work with AC voltage?
In summary, AC appliances are not affected by the changing polarity of AC voltage because they do not require a specific positive and negative supply like batteries. Changing currents allow for efficient voltage transformation, making AC useful for powering electronic circuits. Most appliances convert AC to DC through transformers and other techniques in order to power their internal systems. Therefore, the changing polarity of AC voltage does not pose a problem for appliances.
Aditya Mysore
how do the appliances work with AC voltage when the polarity keeps changing?
Think of a resistance load. For the first half of an AC cycle voltage is plus and current is plus. Power is voltage times current, thus plus. In the second half of the cycle voltage is minus and current is minus, but voltage times current is still plus. (-1 * -1 = +1). So the directin of power flow is the same through the whole cycle.
And for motors look e.g. here
And: Hello, Aditya, welcome to PF :smile: !
primarily, because in general, AC appliances are not polarity conscious ... that is, they don't need a specific + and - supply like from a batteryDave
A light bulb does not care that the voltage is changing and polarity is reversing because it has a slow response time.
For systems that are sensitive, the AC is converted to DC. In fact, that is true for most appliances (other than toasters, heaters, AC motors, etc).
There is nothing in your TV that runs off the AC directly. It is converted to many different DC voltages. Same for your Computer.
Then you mean to say the current keeps changing its direction?
yes. that's its definition ... AC = Alternating Current :smile:
Dave
Well
Dave
Well then how can an appliance handle such kind of a thing when the current in the circuit keeps changing its direction?
That was my initial question.
Did you read my reply? #5
Yes I think you are right. Thanks :)
It doesn't matter that I am right :smile:, does it fully explain what you wanted to understand?
In order to efficiently transform voltages you need AC power. The changing currents allow one to use transformers to efficiently change voltage without power loss. For example, 110VAC 0.1 Amp (11 watts) applied to a proper transformer would power a circuit that requires 5VAC 2.2A (also 11Watts). That ease of voltage transformation is one thing that make AC very useful. Then, after transforming voltage, there are very simple techniques to convert the AC to DC, which most electronic circuits require.
Your PC power supply (and most wall-wart chargers) do this to an extreme. They convert 110VAC/60Hz directly to DC and then chop it back into AC at high frequencies (100KHz or higher) to put it through a transformer that creates many AC output voltages. Then they convert those back to DC, say 5V, 12V, and 3.3V to power a PC. For various other reasons, creating 100KHz AC allows efficient power transfer through a cheaper, smaller transformer.
So, AC is not a problem for appliances, it actually makes it easy to transform the power to voltages needed by an electronic system. Most don't actually run on AC internally.
FAQ: How do the appliances work with AC voltage?
How does an appliance use AC voltage?
When an appliance is plugged into an AC outlet, the AC voltage flows through the appliance's power cord and into a transformer. The transformer converts the AC voltage to the appropriate voltage for the appliance to use.
What is the difference between AC and DC voltage?
AC (alternating current) voltage flows in a back-and-forth motion, constantly changing direction. DC (direct current) voltage flows in one direction only. Most appliances use AC voltage, while batteries and some smaller devices use DC voltage.
How does an appliance regulate the amount of voltage it needs?
Most appliances have a built-in voltage regulator or control unit that monitors and adjusts the voltage as needed. This ensures that the appliance receives the correct amount of voltage to function properly.
Can an appliance be damaged by incorrect AC voltage?
Yes, an appliance can be damaged if it receives too much or too little AC voltage. Too much voltage can cause the appliance to overheat and potentially catch fire. Too little voltage can prevent the appliance from functioning properly.
Why is AC voltage more commonly used than DC voltage?
AC voltage is more commonly used because it is easier to produce and can be transmitted over longer distances without significant loss of power. It is also safer to use for larger appliances and devices.
