How do three flywheels, one in each axis, behave?
In summary, when three rotating reaction wheels are attached to each other at 90 degree angles and torque is applied to the assembly, it will precess based on the vector sum of the individual angular momentums. This precession will not resist torque from all directions, and the assembly will behave as if it has a single wheel with √3 times the angular momentum. The axis of this virtual wheel will be parallel to the diagonal of an imaginary cube with a corner having the three original wheel axes as edges. This same logic applies to any complex rigid assembly with multiple wheels and non-zero total angular momentum.
Eloc Wolsniw
I have been struggling to visualize how three rotating reaction wheels on bearings and affixed to each other at 90 degree angles, one at each axis (picture the kind of 3-axis reaction devices used in satalites), would behave when torque is applied to the whole assembly. If all three reaction wheels where spinning clockwise (viewed from the outside of each wheel), how would the device precess? Would it precess at all, or would it resist torque from all directions?
Please tell me your thoughts.
The three wheels each have some angular momentum. The vector sum of these is the total angular momentum and controls how the assembly as a whole will precess under an external torque. Conclusion: No, it will not resist torque from all directions. It will act as if it had a single wheel with ##\sqrt{1^2+1^2+1^2}=\sqrt{3}## times the angular momentum. The axis of this virtual wheel will be parallel to the diagonal of an imaginary cube with a corner having the three original wheel axes as edges.
The same logic that leads to the conclusion that a single wheel precesses under an external torque applies with equal force to an arbitrarily complex rigid assembly with multiple wheels and non-zero total angular momentum.
Likes hutchphd and Eloc Wolsniw
Yes. I see it now! Thank you very much. This was really bugging me.
Likes berkeman
Related to How do three flywheels, one in each axis, behave?
1. How do the flywheels interact with each other?
The three flywheels, each positioned in a different axis, will interact with each other through the conservation of angular momentum. This means that any change in the rotation of one flywheel will cause a corresponding change in the rotation of the other two flywheels. This interaction allows for the flywheels to work together to stabilize the system and maintain its orientation.
2. What happens if one of the flywheels stops spinning?
If one of the flywheels stops spinning, the other two flywheels will continue to rotate and maintain the system's orientation. However, the system may become less stable and may experience some wobbling or tilting until the stopped flywheel is restarted or replaced.
3. How do the flywheels affect the overall stability of the system?
The flywheels play a crucial role in maintaining the stability of the system. By spinning in different axes, they provide a counteracting force to any external forces acting on the system. This helps to keep the system balanced and prevents it from tipping over or changing its orientation.
4. Can the speed of the flywheels be adjusted?
Yes, the speed of the flywheels can be adjusted to control the stability and orientation of the system. By changing the speed of one or more flywheels, the system's overall rotation can be altered, allowing for precise control and adjustments.
5. Are there any limitations to using three flywheels in this way?
While using three flywheels in this configuration can provide excellent stability and control, there are some limitations. The size and weight of the flywheels can impact the system's overall weight and maneuverability. Additionally, there may be practical limitations on the maximum speed that the flywheels can achieve, which may affect the system's responsiveness.
  • Classical Physics
  • Classical Physics
  • Other Physics Topics
  • Mechanical Engineering
