How Do Three Spin-1/2 Particles Combine to Form States with Total Spin 3/2?
  • Thread starter BeyondBelief96
In summary: You make the assumption that ## \left | +z, +z, +z\right>## is an eigenstate, sort of like how ## \left | \pm{z}, \pm{z} \right > ## were eigen states of two interacting particles.
BeyondBelief96
Determine the four states with ##s = \frac{3}{2}## that can be formed by three spin ##\frac{1}{2}## particles. Suggestion: Start with the state ##\ket{\frac{3}{2}, \frac{3}{2}}## and apply the lowering operator. [/B]
$$S^{2}\ket{s, m} = \hbar^2 s(s+1)\ket{s, m}$$
$$S_z \ket{s, m} = \hbar m \ket{s, m}$$
What we want to do is to find what four combinations of interacting spin ##\frac{1}{2}## particles give us a total angular momentum of spin ##\frac{3}{2}##. \newline
Consider three interacting spin ##\frac{1}{2}## particles. A natural basis set is to label the states by the value of ##S_z## for each of the particles:
$$ \ket{+z, +z, +z}, \ket{+z, +z, -z}, \ket{+z, -z, +z},\ket{-z, +z, +z}, \ket{+z, -z, -z}, \ket{-z, +z, -z}
\ket{-z, -z, +z}, \ket{-z, -z, -z} $$
Can we reason out with physical intuition what the ##s## and ##m## values will be for each of these states? Consider the first state:
$$ \ket{+z, +z, +z} = \ket{\frac{1}{2}, \frac{1}{2}, \frac{1}{2}} $$
##s = \frac{1}{2}## for each particle, and m =It was here I realized that when we worked through this problem in class but for a system of two interacting particles, we were evaluating the values of s and m for the eigenstates of the hamiltonian. Does this mean I need to find what the eigenstates of the Hamiltonian will be for a system of three interacting particles? How do I even go about doing so?
Also, sorry, I'm new to posting here, and I thought it would be able to read LaTeX since I've seen others use it, but I must be doing something wrong, I hope you can read the equations okay.
Enclose math in-line math with ## at the beginning and the end; enclose stand-alone math with $$ at the beginning and the end.
LaTeX here doesn't support the Dirac notation package. For kets, try, for example, \left| +z, +z, +z \right> , which gives ##\left| +z, +z, +z \right>##.
You need to find states that are eigenstates of ##\hat{S}^2## with eigenvalue ##\frac{15}{4} \hbar^2## (or ##s=3/2##) for three spin-1/2 particles. As the problem suggests:
You start with the stretched state ## | \frac{1}{2}, \frac{1}{2}, \frac{1}{2} \rangle##, which has necessarily maximum spin ##s=3/2## and maximum ##m=3/2## (it is the same as ##| s=\frac{3}{2}, m=\frac{3}{2}\rangle##), and then use the lowering operator ##\hat{S}_- = \hat{S}_{1-} + \hat{S}_{2-} + \hat{S}_{3-}## to find the eigenstates with other values of ##m##.
Likes George Jones
The question also says "apply the lowering operator as in (5.36)." You should look at (5.36) and the steps that led to (5.36) (for two spin 1/2 particles), and then try to do what the text and @DrClaude suggest for three spin 1/2 particles.
Okay, so I did so and got ##(\hat{S}_1 + \hat{S}_2 + \hat{S}_3)\left | \frac{1}{2}, \frac{1}{2}, \frac{1}{2} \right > = \hbar (\left | -z, +z, +z \right > , \left | +z, -z, +z \right >, \left | +z, +z, -z \right >## following the example from the book, only how do I express this state in terms of eigenstates, given that I don't even know what the eigenstates of 3 interacting particles are?
I feel as if there's something fundamental connection I'm not seeing. I'm assuming ## \left | +z, +z, +z\right> ## is an eigenstate, sort of like how ## \left | \pm{z}, \pm{z} \right > ## were eigen states of two interacting particles? So we make the assumption that it would follow the same logic? I'm not sure why we are applying the lowering operator as well.
Be careful, you are missing a numerical factor when calculating the action of the lowering operator on the state. Also, you forgot the minus sign on the operators, ##\hat{S}_{1-}##, and that should be + signs on the right-hand side, not commas.
The idea is that you want to express the three-particle states ##|s,m\rangle##, which are eigenstates of ##\hat{S}^2## and ##\hat{S}_z##, in terms of the single-particle states
| \pm z \rangle_1 \otimes | \pm z \rangle_2 \otimes | \pm z \rangle_3 \equiv | \pm z, \pm z, \pm z \rangle
The starting point is a state that you know how to express in terms of single-particle states, which are the stretched states
|s=\frac{3}{2},m=\frac{3}{2}\rangle = | + z, + z, + z \rangle
or
|s=\frac{3}{2},m=-\frac{3}{2}\rangle = | - z, - z, - z \rangle
since only all particles having spin pointing in the same direction can result in the maximum possible total spin and spin projection.
Then you can find the other states of the same total spin using raising or lowering operators,
\hat{S}_{-} |s=\frac{3}{2},m=\frac{3}{2}\rangle = \left( \hat{S}_{1-} + \hat{S}_{2-} + \hat{S}_{3-} \right) | + z, + z, + z \rangle
or
\hat{S}_{+} |s=\frac{3}{2},m=-\frac{3}{2}\rangle = \left( \hat{S}_{1+} + \hat{S}_{2+} + \hat{S}_{3+} \right) | - z, - z, - z \rangle
On the left-hand side, you will get ##\hat{S}_{-} |s=\frac{3}{2},m=\frac{3}{2}\rangle = c |s=\frac{3}{2},m=\frac{1}{2}\rangle## (I'll let you look up the factor ##c## that appears there), so by applying the operator on the right-hand side you will get a representation of ##|s=\frac{3}{2},m=\frac{1}{2}\rangle## in terms of single-particle states. You can then repeat the procedure to get the other values of ##m##.
Likes jim mcnamara
FAQ: How Do Three Spin-1/2 Particles Combine to Form States with Total Spin 3/2?
What is the "John Townsend Problem 5.7" and why is it significant?
The "John Townsend Problem 5.7" is a mathematical problem that was proposed by British physicist John Townsend in 1902. It is significant because it was one of the first attempts to explain the behavior of gases at very low pressures, and it led to the development of the Townsend discharge equation.
What is the Townsend discharge equation and how is it used?
The Townsend discharge equation is a mathematical formula that describes the relationship between the electric field, gas pressure, and the number of ionizations in a gas. It is used to calculate the breakdown voltage of a gas at a given pressure and distance between electrodes.
How does the Townsend discharge equation relate to the study of plasma physics?
The Townsend discharge equation is a fundamental equation in the study of plasma physics, as it describes the behavior of electrons and ions in a gas under the influence of an electric field. It is used in various fields such as astrophysics, fusion research, and plasma processing.
What are some real-world applications of the Townsend discharge equation?
The Townsend discharge equation has numerous applications in fields such as gas discharge lighting, plasma processing of materials, and plasma propulsion for spacecraft. It is also used in the design and operation of gas-filled radiation detectors.
What are some limitations of the Townsend discharge equation?
The Townsend discharge equation is based on several assumptions, such as the gas being uniform and the electric field being parallel to the electrodes. These assumptions may not hold in real-world situations, leading to deviations from the predicted results. Additionally, the equation does not take into account other factors that may affect the behavior of the gas, such as temperature and gas composition.
