John Constantine
- 19
- 4
- TL;DR Summary
- energy conversion
Usually, I like to take a physical approach to phenomena that occur in everyday life. But I feel difficult to solve problems because I don't have higher education
My question stems from this question (What's the difference between running up a hill and running up an inclined treadmill?), which is similar to this one, but a little different.
Assume the following circumstances.
Factors such as air resistance are not considered.
There are two identical people, A and B. A is riding on an execise bike, which is fixed to the ground, and B is riding on a road bike. Press the pedal at the same torque. If the torque required to turn the pedal at a constant angular velocity is the same in both cases, The pedals will rotate at a same angular velocity in both cases ( If A and B push pedals at same torque) ---> I think Since they have traveled the same distance with the same magnitude of torque, in both cases what torque did to the object would be the same.
If I compare how the energy consumed by A and B was converted
Calories(energy) consumed by A = Energy required to rotate the wheel
Calories(energy) consumed by B = Energy required to rotate the wheel + translational energy of bicycle and B ( Kinetic energy)
From a certain point of view, the case of B is likely to consume more energy due to translational kinetic energy than the case of A.
But the two apparently pedaled the same distance at the same torque. What's going on? What's the point I'm missing or wrong with?
