How do we conclude that (a,b)=1
  • MHB
  • Thread starter evinda
In summary, we are trying to prove that $gcd(a,b,c)=1$ in the equation $ax^2+by^2+cz^2=0$ where $a,b,c$ are square-free and do not have any common prime factors. By considering the equation and its solutions, we can conclude that $a,b,c$ do not have any common prime factors with each other, thus proving that $gcd(a,b,c)=1$.
evinda
MHB
3,836
Hi! (Nerd)
Suppose that we have the equation $ax^2+by^2+cz^2=0, a,b,c \in \mathbb{Q}$.
Without loss of generality, we suppose that $gcd(a,b,c)=1$.
Also, we can consider that $a,b,c$ are square-free.
We can suppose that $(a,b)=(b,c)=(a,c)=1$.
Proof of the last sentence:
Let $d=(a,b)>1$
Since $a,b$ are square-free $\Rightarrow d$ is also square-free.
$$a=da' \\ b=db'$$
$$\Rightarrow (a',b')=1$$
It stands that $(d,c)=1$.
Proof:
Let $d'=(d,c)>1$
$$\Rightarrow \begin{Bmatrix}
d' \mid d\\ \\
d' \mid c
\end{Bmatrix} \Rightarrow \begin{Bmatrix}
d' \mid a\\ \\
d' \mid c
\end{Bmatrix} \Rightarrow d' \mid (a,b,c)=1, \text{ Contradiction} \Rightarrow (d,c)=1$$
So, when $(x,y,z)$ an integer solution of $ax^2+by^2+cz^2=0 \\ \Rightarrow d(a'x^2+b'y^2)+cz^2=0 \\ \Rightarrow d \mid cz^2, (d,c)=1 \Rightarrow d \mid z^2$
Since $d$ is square-free, $d \mid z^2 \Rightarrow d \mid z \Rightarrow z=dz'$
The initial equation:
$$a'x^2+b'y^2+(cd)z^2=0$$
We concluded to an equivalent equation, where $(a',b')=1$
With the same procedure, we prove that $(a,b)=(b,c)=(c,d)=1$
Could you explain me why, having the equivalent equation, we conclude that $(a,b)=1$ ?
Mathematics news on Phys.org
Hi there! It seems like you are trying to prove that $gcd(a,b,c)=1$ in the given equation. Let me explain it in a simpler way:
1. Suppose we have the equation $ax^2+by^2+cz^2=0$, where $a,b,c$ are integers and $gcd(a,b,c)=1$.
2. Without loss of generality, we can assume that $a,b,c$ are square-free, meaning they do not have any repeated prime factors.
3. We can also assume that $(a,b)=(b,c)=(a,c)=1$, which means that $a,b,c$ do not have any common prime factors.
4. Now, let's consider the equation $ax^2+by^2+cz^2=0$ and suppose that $(x,y,z)$ is an integer solution.
5. From the given information, we know that $gcd(a,b,c)=1$, which means that $a,b,c$ do not have any common prime factors.
6. Since $a,b,c$ are square-free, it follows that $gcd(a,b)=gcd(b,c)=gcd(a,c)=1$, which means that $a,b,c$ do not have any common prime factors with each other.
7. Therefore, we can conclude that $(a,b)=(b,c)=(a,c)=1$, which proves the last sentence in the given forum post.
I hope this helps clarify the reasoning behind the proof. Let me know if you have any other questions. Keep up the good work!
FAQ: How do we conclude that (a,b)=1
How do we determine if two numbers (a,b) are relatively prime?
To conclude that (a,b)=1, we need to use the Euclidean algorithm to find the greatest common divisor (GCD) of a and b. If the GCD is equal to 1, then the two numbers are relatively prime and (a,b)=1.
What is the Euclidean algorithm and how does it help us determine if (a,b)=1?
The Euclidean algorithm is a method used to find the GCD of two numbers. It involves repeatedly dividing the larger number by the smaller number until the remainder is equal to 0. The last non-zero remainder is the GCD, and if it is equal to 1, then (a,b)=1.
Can we use any other methods to determine if two numbers are relatively prime?
Yes, there are other methods such as the prime factorization method, the extended Euclidean algorithm, and the binary GCD algorithm. However, the Euclidean algorithm is the most commonly used and efficient method for determining if (a,b)=1.
Is it necessary to find the GCD of two numbers to conclude that they are relatively prime?
No, it is not necessary. If the two numbers share no common prime factors, then they are relatively prime and (a,b)=1. However, finding the GCD is a more efficient way to determine if two numbers are relatively prime.
Why is it important to know if two numbers are relatively prime?
Knowing if two numbers are relatively prime is important in various fields of mathematics, such as number theory, cryptography, and computer science. It also has real-world applications, such as in determining the efficiency of algorithms and in solving problems involving modular arithmetic.
