How Do We Determine the Convergence of These Complex Integrals?
In summary, we discussed the convergence of four different integrals. The first two integrals were shown to converge through direct calculation, while the third integral was proven to converge through a comparison with a known convergent integral. The fourth integral was shown to diverge through a comparison with a known divergent integral. Additionally, a potential method for proving the convergence of the third integral without calculation was discussed.
mathmari
MHB
5,049
Hey! :eek:
I want to check the convergence of the following integrals:
  1. $\displaystyle{\int_2^{\infty}\frac{1}{x\left (\log (x)\right )^2}dx}$
    We have that: \begin{equation*}\int_2^{\infty}\frac{1}{x\left (\log (x)\right )^2}dx=\lim_{b\rightarrow \infty}\int_2^b\frac{1}{x\left (\log (x)\right )^2}dx\end{equation*}
    To calculate the integral $\int_2^b\frac{1}{x\left (\log (x)\right )^2}dx$ we use the substitution $u=\log (x)$.
    We have the following: \begin{align*}\int_2^b\frac{1}{x\left (\log (x)\right )^2}dx & =\int_{\log(2)}^{\log(b)}\frac{1}{e^u\left (\log (e^u)\right )^2}\cdot e^udu \\ & =\int_{\log(2)}^{\log(b)}u^{-2}du \\ & =-\left [u^{-1}\right ]_{\log (2)}^{\log (b)} \\ & =-\left (\frac{1}{\log (b)}-\frac{1}{\log (2)}\right ) \\ & =-\frac{1}{\log (b)}+\frac{1}{\log (2)}\end{align*}
    So, the integral is \begin{equation*}\lim_{b\rightarrow \infty}\int_2^b\frac{1}{x\left (\log (x)\right )^2}dx=\lim_{b\rightarrow \infty}\left (-\frac{1}{\log (b)}+\frac{1}{\log (2)}\right )=-0+\frac{1}{\log (2)}=\frac{1}{\log (2)}\in \mathbb{R}\end{equation*}
    Therefore, the integral $\displaystyle{\int_2^{\infty}\frac{1}{x\left (\log (x)\right )^2}dx}$ converges. Could we show the convergence also without calculating the integral? (Wondering)
  2. $\displaystyle{\int_0^{\infty}e^{sx}\cos (tx)dx}$, wobei $s<0$ und $t\in \mathbb{R}$
    We have that \begin{equation*}\left |e^{sx}\cos (tx)\right |=\left |e^{sx}\right |\cdot \left |\cos (tx)\right |\leq \left |e^{sx}\right |=e^{sx}\end{equation*}
    We have that: \begin{equation*}\int_0^{\infty}e^{sx}=\lim_{b\rightarrow \infty}\int_0^b e^{sx}dx\end{equation*}
    Therfore we get \begin{equation*}\lim_{b\rightarrow \infty}\int_0^b e^{sx}dx=\lim_{b\rightarrow \infty}\left [\frac{1}{s}e^{sx}\right ]_0^b=\frac{1}{s}\lim_{b\rightarrow \infty}\left [e^{sx}\right ]_0^b=\frac{1}{s}\lim_{b\rightarrow \infty}\left (e^{sb}-1\right )=\frac{1}{s}\left (0-1\right )=-\frac{1}{s}\end{equation*}
    So, we have that \begin{equation*}\int_0^{\infty}e^{sx}=-\frac{1}{s}\in \mathbb{R}\end{equation*}
    That means that the integral $\displaystyle{\int_0^{\infty}e^{sx}dx}$ coverges and so the integral $\displaystyle{\int_0^{\infty}e^{sx}\cos (tx)dx}$ also converges.
    Is this correct? (Wondering)
  3. $\displaystyle{\int_0^1\left (\log (x)\right )^2dx}$
    Calculating that integral we get $0$. So, the integral converges.
    Is there also an other way without calculating it? (Wondering)
  4. $\displaystyle{\int_1^{\infty}\frac{x\sqrt{x}}{(2x+1)^2}dx}$
    Could you give a hint for that one? (Wondering)
[*] $\displaystyle{\int_1^{\infty}\frac{x\sqrt{x}}{(2x+1)^2}dx}$
I think it's divergent, since $x>\sqrt{x}$the integral by comparison is greater than
$\frac{1}{2}\int_{1}^{\infty} \,\frac{1}{2x+1}dx-\frac{1}{2}\int_{1}^{\infty} \,\frac{1}{{(2x+1)}^{2}}dx$
the first diverges
the first diverges
I see! (Nerd)
For that one, could we do the following:
We have that $\log (x)\leq x-1$ then $\log^2(x)\leq (x-1)^2$.
We have that $\int_0^1(x-1)^2dx=\ldots =\frac{1}{3}\in \mathbb{R}$. So, the integral of $(x-1)^2$ converges, and from the direct comparison we get that the integral of $\log^2(x)$ converges.
FAQ: How Do We Determine the Convergence of These Complex Integrals?
What is the definition of convergence of integrals?
The convergence of integrals is a mathematical concept that refers to the behavior of an integral as the limits of integration approach a certain value. A convergent integral is one that has a finite limit as the limits of integration approach a specific value, while a divergent integral is one that does not have a finite limit.
How do you determine if an integral is convergent or divergent?
To determine the convergence of an integral, you can use various methods such as the comparison test, limit comparison test, ratio test, root test, or the integral test. These methods involve comparing the integral to known convergent or divergent series or evaluating its limit as the limits of integration approach a certain value.
What is the significance of convergence of integrals in real-world applications?
The convergence of integrals is important in various fields such as physics, engineering, economics, and statistics. It allows us to accurately calculate and analyze quantities such as area, volume, work, probability, and expected values. It also helps in solving differential equations and determining the behavior of functions.
Can an integral be both convergent and divergent?
No, an integral cannot be both convergent and divergent. It can only be one or the other. However, there are cases where an integral may be conditionally convergent, meaning it is convergent but its value depends on the order in which the terms are added.
Are there any special types of integrals that are always convergent or divergent?
Yes, certain types of integrals have well-known convergence or divergence properties. For example, the integral of a continuous function over a finite interval is always convergent, while the integral of a discontinuous function or an unbounded function over an infinite interval is always divergent. However, there are exceptions to these general rules, and it is important to use proper methods to determine the convergence of integrals.
