How do we justify "Natural" Units
In summary: I don't understand. Units don't need to be justified. They are a convention, you simply use them (or not, whatever your preference).In summary, the OP is perplexed by the fact that when using "natural" units, the units themselves are dropped. This allows us to conflate speed and action, which to me have always been different physical quantities.
quickAndLucky
34
How is it that when using "natural" units we drop the units themselves. I understand that you can arbitrarily change the magnitude of a parameter by choosing a new unit. For example Oliver R. Smoot is exactly 1 smoot tall.
However, in natural units with [c]=[h/(2π)]=1 the "smoot" part is left off. Furthermore, leaving off the units allows us to conflate speed and action, which to me have always been different physical quantities.
How do we justify this as it seems like its common practice?
I don’t understand. Units don’t need to be justified. They are a convention, you simply use them (or not, whatever your preference).
I think that the OP is perplexed by the fact that if you calculate something using ##c \approx 3 \times 10^8\, \mathrm{m/s}##, then ##c## has dimensions of length/time, but if you use natural units, then ##c## is dimensionless. Where have the units gone?
To answer the OP, the thing is that dimensioned fundamental constants can be seen as conversion factors between different dimensions. Take mass for instance: in the SI system, it has units of kg, but by the relation ##E=mc^2##, we have that mass is just a form of energy, so we could also express mass as an energy, which is done all the time in particle physics, where masses are often given in MeV. So the constant ##c^2## appears as a conversion factor between mass and energy.
Similarly, it is arbitrary that we measure temperature in units of kelvin, instead of simply stating the temperature as an energy. The Boltzmann constant is the factor that allows to convert between the two (if you look closely, in thermodynamics you will rarely find ##T## by itself, whereas ##kT## is ubiquitous).
Likes Tamar, quickAndLucky and Dale
Perhaps the confusion is that not only the size of the units, but also the dimension of the unit is a matter of convention. For example, the dimension of charge is different in MKS and CGS units. In MKS it has its own dimension, Q, and in CGS it is ##\sqrt{L^3 M T^{-2}}##
Likes quickAndLucky
I like the examples of temperature and mass measured as energy and get
but one of the confusing things with natural units is that the fundamental constants are unitless. Also it is intuitively clear that temperature and energy should be related quantities as they are essentially the macro and micro versions of the same physical phenomina. But it is not clear to me that h bar and c are the same physical quantity.
Don’t look at converting h into c, look at the things that they each convert. For c, it is used to convert time into length, and when you work with spacetime it is clear that those should be the same. It is also used to convert E into B, and since E and B are both part of the overall electromagnetic field they should also have the same units. Similarly for h.
Likes quickAndLucky and DrClaude
As @Dale pointed out, they are not. There can be some confusion coming from the sloppiness of writing
quickAndLucky said:
[c]=[h/(2π)]=1
This is simply a shorthand for ##c=1## and ##\hbar = 1##, not a statement about a relation between ##c## and ##\hbar##.
I confused a student a few days ago by writing something like ##P(+) = P (-) = 1/2##, which brought up the question "Why should the two probabilities be equal?" In general the two probabilities I was considering are not related, but they just had the same value for the situation at hand.
Likes quickAndLucky and Dale
Also, note that when some people say "natural units" they simply mean setting "unimportant" parameters equal to 1 since they do not affect the qualitative properties of the solution. A good example would be to set the mass equal to 1 in a mechanics problem where you are really only interested in solving the resulting differential equation.
Some theorists/mathematician love doing this and it can be very confusing.
Likes DrClaude and quickAndLucky
You can justify different ways for different reasons. Sometimes, it's just convenient. Sometimes there is a good physical reason for doing so to try to identify which units are fundamental and which are derived. When doing relativity, you are talking about geometry so that all of your coordinates should be on equal footing. (You use the same units for measuring, length, width and height. If you did not, then there would be a conversion constant that is physically meaningless to deal with.) We measure distance and time with different instruments and therefore we have c as a conversion constant, but it's physically meaningless in relativity. You can just as easily use meters to measure time and in that case, velocities are dimensionless.
Likes quickAndLucky
One smoot of time would be the time it takes light to travel a distance of 1 smoot. Thus the speed of light is one smoot per smoot, or simply 1.
What I did above was conflate distance and time by measuring them in the same unit, even though I fully realize that distance and time are different physical quantities.
There's nothing wrong with it, so in that sense it needs no justification. But in fact the justification is that it's convenient to do it.
Likes Dale
FAQ: How do we justify "Natural" Units
What are natural units?
Natural units are a system of measurement that use fundamental physical constants, such as the speed of light and Planck's constant, to define the unit of measurement. This eliminates the need for arbitrary conversion factors and makes calculations simpler.
Why do we use natural units?
Natural units are often used in theoretical physics, such as in quantum mechanics and relativity, because they simplify calculations and make physical theories more elegant. They also allow for easier comparison between different systems of measurement.
How do we justify the use of natural units?
The justification for using natural units lies in the fact that they are based on fundamental physical constants, which are believed to be universal and unchanging. Therefore, natural units are considered to be a more fundamental and objective way of measuring physical quantities.
What are the advantages and disadvantages of using natural units?
The main advantage of using natural units is that they simplify calculations and make physical theories more elegant. However, they can also be limiting in certain contexts, such as when dealing with very small or very large quantities. Additionally, natural units may not be intuitive for those unfamiliar with them.
Are there different types of natural units?
Yes, there are different types of natural units depending on the physical constants used to define them. Some examples include Planck units, atomic units, and electron volts. Each type has its own set of fundamental constants and may be more suitable for certain situations.
