How do we know/prove a slope of a line is constant?
In summary, the conversation discusses the definition of a line and the proof that its slope is constant. It also explores different approaches to proving this, including using similar triangles and the concept of corresponding angles. The conversation raises questions about what constitutes an acceptable definition of a line and how this may vary depending on the given information.
lamp23
Before I just accepted that the slope of a line is constant, but I'm wondering if there is an even more fundamental definition of a line.
If one draws two right triangles with a certain Δx and Δy as the legs and wants to prove that the connection of the two hypotenuses is a straight line, then should one prove that the angle between them is 180°?
http://uploadpic.org/storage/2011/thumb_em0Ys5txnYiOhPNXJVSS0UDJe.jpg
I have drawn the original picture in purple and then by SAS one can prove the two triangles congruent and then prove that the corresponding angles ∅ are congruent. Once one proves there is a right angle adjacent to it and a (90-∅) adjacent to that, the sum gives 180°.
Mathematics news on Phys.org
If [itex]f(x) = ax + b[/itex] then [itex]f'(x) = a[/itex], thus the slope is constant. No need to make it any more complicated than that.
Then you are assuming that f(x)=ax+b is the equation of the line. Yet in the derivations for an equation of a line that I have seen (one in Stewart's Calculus), that equation is derived from assuming a =Δy/Δx is constant.
And what about the line whose equation is x = 2? This isn't even a function, let alone one that is differentiable, and yet it is a line.
i have to ask, first, for you: what constitues an acceptable definition of a line?
there is more to the question than meets the eye, and what you will regard as an acceptable proof, depends on what you will allow as "given".
to underscore my point, in euclidean geometry, often lines are NOT defined, but are assumed to have certain properties instead (line is a "primitive concept" and any conceivable object with the properties of a line, is said to be a model for a line).
it is not hard to show, that for any set in the plane satisfying:
L = {(x,y): ax+by = c} (where a,b and c are "constants"). that the equation:
y2 - y1= m(x2 - x1)
has a unique solution m that holds for any pair (x1,y1), (x2,y2) in L; unless b = 0, in which case NO m will work.
but perhaps this is not what you're looking for, without more information, i cannot say.
You don't need that the two triangles are congruent- only similar. That way, you can use different length [itex]\Delta x[/itex] and get a different [itex]\Delta y[/itex]. But because the hypotenuses of the two right triangles are the same line, and the two horizontal sides are parallel, by "corresponding angles" from geometry, we get that the two angles you have labeled "[itex]\phi[/itex]" are congruent so the triangles are similar. Then the ratios of corresponding sides are the same. Since the slope is the ratio of two sides, it is the same at every point no matter what "rise" and "run" you use.
FAQ: How do we know/prove a slope of a line is constant?
How do we determine the slope of a line?
The slope of a line is determined by calculating the change in y-coordinates divided by the change in x-coordinates between any two points on the line. This is represented by the formula: slope = (y2-y1)/(x2-x1).
What is a constant slope?
A constant slope means that the rate of change of the line is consistent and does not vary. This is represented by a straight line on a graph, where every point on the line has the same slope.
How do we prove that a slope is constant?
To prove that a slope is constant, we can use the slope formula to calculate the slope between multiple points on the line. If the slope remains the same for all points, we can conclude that the slope is constant.
Can a line have a constant slope and not be straight?
No, a line with a constant slope must be straight. This is because a constant slope means that the rate of change of the line is consistent, and a straight line is the only shape that maintains a consistent rate of change.
How does a constant slope relate to the direction of a line?
The direction of a line is determined by its slope. A positive slope means the line is increasing from left to right, while a negative slope means the line is decreasing from left to right. A constant slope means the line maintains the same direction throughout its entire length.
15K
