B How do we know what would happen if time reversed?
  • B
  • Thread starter Thread starter olamosey
    Time Time reversal
Sean Carroll's lectures highlight the CPLEAR experiment, which indicates that weak interactions differ when time is reversed. However, the assumption that reversing a particle interaction equates to actual time reversal is questioned. There is uncertainty about whether kaons would convert to anti-kaons at the same rate if time were truly reversed. The discussion emphasizes that this assumption lacks empirical support, as it presumes no other changes occur during the reversal. Ultimately, the complexities of time reversal in physics remain unresolved.
olamosey
TL;DR Summary
The weak interactions are different going forward and going backwards in time. But how can we know this, since we can’t actually reverse time?
In Sean Carroll's lectures Mysteries of Modern Physics: Time, he talks about the the CPLEAR experiment, which showed that the weak interactions are different going forward and going backwards in time. But it seems like there is a big assumption: reversing a particle interaction means that it is happening backwards in time. But it isn't, no time reversal is actually happening. How do we know that if we could actually reverse time, we would see kaons turning into anti-kaons at the same rate?
We don't. You are correct in that there is an assumption that nothing else changes when we 'reverse' time.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
