How do we make our own non sticky viscous gel?
  • Thread starter Thread starter abdulbadii
    viscous
The discussion centers on creating a non-sticky, viscous gel suitable for use as a suspending or bedding buffer during PCB assembly and soldering. Participants explore various base materials, including starch or fine wood sawdust mixed with water and possibly glue, to achieve the desired viscosity. Concerns about stickiness lead to suggestions for neutralizing agents like acetone. The conversation also touches on the possibility of using PVA and Borax to create slime or a firmer gel known as flubber. Specific applications for the gel are discussed, including the need for details on the type of components and soldering methods, such as reflow or wave soldering, to tailor the gel's properties effectively for PCB assembly.
abdulbadii
TL;DR Summary
How do we make our own non or very little sticky viscous gel as ever overheard and glimpsed a chat circle of 3-4 persons conferring one another about how making it correctly and had successfully realized one in hand of one of them
But that casual time quite short so one would have no chance to learn or perceive of it well, Iirc it involved base matter e.g. starch or maybe fine wood sawdust mixed with water and maybe glue, then if too sticky it'd be neutralized with some acetone (or s.t. else better)
Anyone really gone through it so that will share experiences now please ?
Is this the slime you can make with PVA and Borax? It can be mixed to be slimy or a firmer version called flubber.
Unfortunately haven't heard that due to my noobs
The point is the gel viscosity is needed to be used reliably enough as suspending/bedding buffer for PCB onto which a component is being soldered
Looks like you came to the right place; I'm quite familiar with various PCBA assembly and soldering processes. Can you say more about your application? What kind of component do you need to hold in place for the soldering process? Is this reflow or wave soldering? Top side or bottom side of the PCBA? The more details you can give us, the better our answers can be.
Likes jim mcnamara, anorlunda and dlgoff
Philips Hue was the very first provider of smart LED bulbs that can be controlled wirelessly. Over the years, as Philips sold ever improved models of smartbulbs, it became very difficult to identify exactly which model one of their bulbs is. Once I've installed a smart bulb, there is some additional information in the Hue app about the bulb model, but even then, I found that it requires information from both the app and from what's printed on the outside of bulb to be sure what the actual...
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
Hot Threads
