MHB How Do We Prove That 'P' Doesn't Vary for Different Free Variables?
  • Thread starter Thread starter mathworker
    Particular solution
mathworker
I am studying Introduction to linear Algebra by Gilbert Strang while calculating the particular solution P for $Ax=b$,he made the free variables $0$ to calculate the particular solution and said that P along with linear combinations of null space solutions make up the complete set.
I understood that particular solution is 'particular' because there is only one solution to system of equation but how do we prove that 'P' doesn't vary for different free variable ( I mean other than $0$)??​
Re: particular sollution for Ax=b
A particular solution definitely varies with the choice of values of free variables because these values are a part of a solution. But the set of all solutions to the system does not depend on the choice of a particular solution.
There is the following fact. Let $L$ be a linear subspace and let $v$ be a particular vector (not necesarily in $L$). If $v'\in L+v$, then $L+v=L+v'$. Indeed, suppose that $v'=u+v$ where $u\in L$. Then an arbitrary vector in $L+v$ has the form $w+v$ where $w\in L$. But $w+v=w+v+u-u=(w-u)+v'$ and $w-u\in L$. The fact that $L+v'\subseteq L+v$ is proved similarly.
Returning to the system of linear equations, $L$ is the null space of $A$ and $v,v'$ are particular solutions. The choice of a particular solution does not change the set of all solutions.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
