How Do You Apply the Quotient Rule with Square Roots?
In summary, the problem is that you are trying to move the square root up, and you may want to try the quotient rule or the logarithmic differentiation.
sleepless
I have the answer to this problem but I am stumped as how to get there. Here it is
h(x)=e^x/5/sqrt2x^2-10x+17, I'm getting stuck moving the square root up. Help
Hi sleepless,
Welcome to MHB! I'm not exactly sure what problem you are trying to solve. Try to be very precise with parentheses. Is this what you want to take the derivative of?
\(\displaystyle \frac{\frac{e^{x}}{5}}{\sqrt{2x^2-10x+17}}\)?
Or is it
$ h(x) = \dfrac{e^{x/5}}{\sqrt{2x^2-10x+17}}$
With square roots note that $\sqrt{x} = x^{1/2}$ and don't forget the chain rule where appropriate (which you will need in this example)
Hello, sleepless!
. . h(x) = e^x/5/sqrt2x^2-10x+17.
i'm getting stuck moving the square root up. .Why do you want to do that?
I'll take a guess as to what the problem is . . .
. . [tex]h(x) \;=\;\frac{e^{\frac{x}{5}}}{\sqrt{2x^2 - 10x + 17}} \;=\;\frac{e^{\frac{1}{5}x}}{(2x^2 - 10x + 17)^{\frac{1}{2}}}[/tex][tex]\text{Quotient Rule:}[/tex]
. . [tex]h'(x) \;=\; \frac{(2x^2-10x+17)^{\frac{1}{2}}\cdot e^{\frac{1}{5}x} \!\cdot\!\frac{1}{5} \;-\; e^{\frac{1}{5}x}\!\cdot\!\frac{1}{2}(2x^2-10x+17)^{-\frac{1}{2}}(4x-10)} {2x^2 - 10x + 7}[/tex]
. . . . . . [tex]=\;\frac{\frac{1}{5}e^{\frac{x}{5}}(2x^2 - 10x + 17)^{\frac{1}{2}} \;-\; e^{\frac{x}{5}}(2x-5)(2x^2-10x+17)^{-\frac{1}{2}}}{2x^2-10x+17} [/tex]
Multiply numerator and denominator by [tex](2x^2-10x + 17)^{\frac{1}{2}}[/tex]
. . [tex]h'(x) \;=\;\frac{\frac{1}{5}e^{\frac{x}{5}}(2x^2-10x + 17) \;-\; e^{\frac{x}{5}}(2x-5)}{(2x^2-10x+17)^{\frac{3}{2}}} [/tex]
. . . . . . [tex]=\;\tfrac{1}{5}e^{\frac{x}{5}}\!\cdot\!\frac{(2x^2 - 10x + 17) \;-\; 5(2x-5)}{(2x^2-10x+17)^{\frac{3}{2}}}[/tex]
. . . . . . [tex]=\;\tfrac{1}{5}e^{\frac{x}{5}}\!\cdot\!\frac{2x^2 - 10x + 17 - 10x + 25}{(2x^2-10x+17)^{\frac{3}{2}}} [/tex]
. . . . . . [tex]=\;\tfrac{1}{5}e^{\frac{x}{5}}\!\cdot \!\frac{2x^2-20x + 42}{(2x^2-20x+17)^{\frac{3}{2}}}[/tex]
. . . . . . [tex]=\;\tfrac{2}{5}e^{\frac{x}{5}}\!\cdot\!\frac{x^2-10x + 21}{(2x^2-10x+17)^{\frac{3}{2}}}[/tex]
[tex]y = \frac{e^{x/5}}{\sqrt{2x^2-10x+17}}[/tex]
[tex]\ln{y} = \frac{x}{5} - \frac{1}{2}\ln(2x^2-10x+17)[/tex]
[tex]\frac{y'}{y} = \frac{1}{5} - \frac{2x-5}{2x^2-10x+17}[/tex]
[tex]\frac{y'}{y} = \frac{2x^2-20x+42}{5(2x^2-10x+17)}[/tex]
[tex]y' = \frac{e^{x/5}}{\sqrt{2x^2-10x+17}} \cdot \frac{2x^2-20x+42}{5(2x^2-10x+17)}[/tex]
[tex]y' = \frac{2e^{x/5}(x^2-10x+21)}{5(2x^2-10x+17)^{\frac{3}{2}}}[/tex]
don't you love logarithmic differentiation?
FAQ: How Do You Apply the Quotient Rule with Square Roots?
What is the quotient rule with square roots?
The quotient rule with square roots is a mathematical rule used to simplify expressions involving square roots. It states that the quotient of two numbers, each with a square root, can be simplified by dividing the numbers inside the square roots and taking the square root of the result.
How is the quotient rule with square roots applied?
The quotient rule with square roots is applied by dividing the numbers inside the square roots and taking the square root of the result. For example, the expression √8/√2 can be simplified to √(8/2) = √4 = 2.
Can the quotient rule with square roots be used with any numbers?
Yes, the quotient rule with square roots can be used with any numbers, as long as they have square roots. It is a general rule that applies to all numbers with square roots.
What are some common mistakes when using the quotient rule with square roots?
Some common mistakes when using the quotient rule with square roots include forgetting to take the square root of the result, and not simplifying the numbers inside the square roots before dividing them.
Why is the quotient rule with square roots important?
The quotient rule with square roots is important because it allows us to simplify complex expressions involving square roots, making them easier to solve. It is also a fundamental rule in algebra and is used in various applications in mathematics and science.
