How Do You Calculate Entropy and Reversibility in Irreversible Processes?
In summary, the entropy of fusion is given by ΔS = Latent heat/Tmelting for unit quantity of substance. If we introduce a transfer fluid and place this in contact with the hotter body at equilibrium then we can create a reversible path.
  • #36
Gavroy said:
okay, i think i did not understand this. in this case, we have a change in entropy, why do you call this process reversible? i thought that a proper definition of reversible is ΔS=0 and nothing else, where am i wrong?
You are wrong because the proper definition of reversible is not ΔS=0. The physical definition of ΔS is not clear in that equation. In order for the definition to be valid, one would have to state in words what ΔS means.
Here is the proper definition of reversible. A reversible process is defined as a process where entropy is not created. If ΔS is defined as the entropy that is created in a reversible process, then ΔS=0. However, if ΔS is defined as the entropy that is transferred to a body in a reversible process, then ΔS can take on any real value at all.
The symbol, ΔS, can be used to designate two entirely different types of process. First, ΔS can be the change of entropy due to the creation of entropy. Second, ΔS can be the change of entropy due to entropy transport. If you think the symbol ΔS always means the creation of entropy, then you are wrong.
A process is reversible when entropy isn't created inside a body. However, it is still possible for the entropy in a body to change because entropy is transported into (ΔS>0) or out of it (ΔS<0). When describing a reversible process, it is customary to let ΔS mean the change due to entropy transport.
A process is adiabatic when entropy isn't transported into or out of a body. However, it is still possible for entropy to change due to the creation of entropy. When describing an adiabatic process, it is customary to let ΔS be the change due to entropy creation.
A process can be both irreversible and adiabatic. In which case, the change in entropy of a body has two components. First, there is the change in entropy due to entropy transport. That can be positive or negative. Second, there is the change in entropy due to entropy creation. That is always positive. It is helpful in such a case to separately identify each component.
In a typical textbook problem, one is asked to calculate ΔS for a Carnot engine that is doing work. The Carnot cycle is by definition reversible. Therefore, there is no creation of entropy. However, entropy is transferred from the hot reservoir to the cold reservoir. By custom, ΔS is the change in entropy of the cold reservoir due to the transport.
The Carnot engine works by the spontaneous transfer of entropy from the hot reservoir to the cold reservoir. If ΔS is the change in entropy of the cold reservoir due to entropy transfer, then the Carnot engine causes ΔS>0. If ΔS is the creation of entropy by the Carnot engine, then ΔS=0. If ΔS is the change in entropy of the hot reservoir due to entropy transfer, then the Carnot engine causes ΔS<0. Note there are three "correct" answers that vary with the definition of ΔS.
The Carnot refrigerator works by the forced transfer of entropy from the cold reservoir to the hot reservoir. If ΔS is the change in entropy of the cold reservoir due to entropy transfer, then the Carnot engine causes ΔS<0.
You are wrong if you think that the symbol ΔS means the same thing to every reader every time it is written down. Sometimes ΔS stands for the creation of entropy, sometimes ΔS stands for the transfer of entropy, and sometimes ΔS stands for some combination of creation and transfer. ΔS has no meaning unless the user states in words what ΔS means. No proper definition can use the symbol ΔS unless it is defined elsewhere in words.
Do you have any questions about this answer?
Science news on Phys.org
  • #37
Gavroy said:
so all isobaric, isochoric, isothermic and adiabatic processes are reversible(if we are talking about ideal processes using an ideal gas?)
Yes, if by ideal you mean this.
An "ideal process" is one where no entropy is created.
If this is what you meant by ideal, then all the processes that you described above are reversible. If fact, they would still be reversible even if one didn't use an ideal gas.
I recommend that you use the word ideal less often. This is another word that changes its meaning. When talking about an engine or refrigorator, ideal usually means without changing entropy.
Allow me to rewrite the idea behind your sentence.
All isobaric, isochoric, isothermic and adiabatic processes are reversible if the processes do not create entropy.
The previous sentence is correct and unambiguous.
  • #38
Gavroy said:
well, my question is: why is dS=dQ_rev/T, what is this reversible for? why would this definition be wrong if i calculate the change in entropy of a nonreversible process? or why do people stress this "reversible" in this definition?
If the measurement is done on an irreversible process, the value for the change of entropy may not be reproducible. Frictional forces will cause the answer to depend explicitly on the speed of the process and other things. Let me give a concrete example.
Suppose you do an experiment where you want to measure the amount of heat given off by an ice cube that is floating on the surface of water in a container. You want to measure the difference in temperature in the water that occurs when the ice cube is completely melted.
1) Suppose the liquid water in the container is initially just slightly more than the melting temperature of ice. Assume that the container is very large compared to the ice cube. Thus, there is far more liquid water in the tank than ice.
This type of measurement is approximately reversible because entropy is not created. When energy enters the ice by conduction, there is little creation of entropy. You can calculate the creation in entropy by calculating dS where the energy is transferred at nearly equal temperatures. The creation of entropy is close to zero.
As the ice melts, the liquid water it gives off is exactly at the melting point of ice. One may have to wait a long time for the ice to melt. However, the ice cube will remain still. The water that comes off the melting ice stays on top of the surface.
2) Suppose the liquid water in the container is initially much hotter than the ice. Assume that the water is a few degrees short of boiling. One places the ice cube in the water.
This type of measurement is completely irreversible because entropy will be created. When the energy enters the ice by heat conduction, entropy will be created.
As the ice melts, the liquid water it gives off is at the melting point of ice. However, this water is surrounded by water at a higher temperature. The high temperature water has a lower density than the ice water. Therefore, the ice water sinks. The convection current will generate turbulence, so the ice block moves around during the measurement. The motion of the ice block will be effectively random. The amount of entropy created will vary with the motion of the ice block. So the entropy generated is both large and variable. The measurement of entropy won't be reproducible.
Note that I am including the expansion of ice. At temperatures near boiling, the hot water will be less dense than ice.
I think that is one way to think of it. Irreversible processes are usually associated with some random or chaotic process. Therefore, the measurement of thermodynamic properties using irreversible processes usually becomes irreproducible.
Another way to think of it is in terms of frictional forces. Frictional forces and their ilk often result in chaotic behavior. Frictional forces also create entropy.To avoid the chaotic behavior, avoid processes that create entropy. In other words, for reproducibility stick with reversible processes.
  • #39
Darwin, I asked you for a quantitative explanation of your entropy transferred and entropy created proposition, a question you skillfully avoided.
So in response to my question how about working through this example in the light of your proposition and explaining how Gavroy is mistaken.
10 litres of a monatomic ideal gas is expanded from an intial pressure of 10 atmospheres to 1 atmosphere.
Calculate and compare the entropy and energy changes for
(1) Adiabatic reversible expansion
(2) Adiabatic irreversible expansion
These can all be calculated by using 'ideal' process equations and clearly show that they are different
For example I calculate the work done to be
(1) 9141 joules - reversible
(2) 5474 joules - irreversible
Can you explain this?
  • #40
You also did not specify the initial temperature, nor the initial molar amount of gas. I don't think it matters in the problem. I was able to work the problem as presented for a monotonic gas.
The power law exponent of volume for a monotonic gas is 1.5. In other words, for a monotonic gas undergoing a adiabatic expansion or contraction:
P_1 V_1^3/2=P_2 V_2^3/2
where P is the pressure, V is the volume, the initial condition is _1 and the final condition is _2. Sorry I don't have a LaTex editor to write the equations in a more formal way.
Given your initial pressure, your final pressure, and the initial volume of 10 Liters.
Final volume = 46 Liters
Note that 1 atmosphere = 1.01×10^5 Newtons/meter^2.
Using the adiabatic expansion formula, the initial volume and the final volume, I calculated the work done by the adiabatic gas. The work done by the gas is the volume integral of pressure. Again, I am sorry that I don't have a LaTex editor. I did the integral with the adiabatic expansion formula for pressure.
The work done by the gas is during the expansion is 1.07×10^5 Joules.
In a reversible adiabatic expansion, no entropy is transported. Therefore, there is no heat transfer. There are no frictional forces. There is only work exerted by the elastic force of the gas.
The change in energy of the gas is equal to the negative of the work done by the gas. The only force exerted by the gas Therefore, the change in energy of the gas during the adiabatic transfer is -1.07×10^5 Joules.
In a reversible process, no entropy is created. Since no entropy is created, and no entropy transferred, the change of entropy of this gas during the expansion is 0 (i.e., zero).
ΔE=-1.07×10^5 Joules
ΔS=0.
Here is where the problem comes in. You did not describe how this expansion becomes irreversible. I hypothesize that you were thinking of a frictional force on the movable piston. However, you did not give me any idea of the size of the force. You did not give me a friction coefficient, a normal force, or anything that can be used to determine the size of the frictional force. The frictional force can be anything.
I have never heard of an "ideal frictional force". Therefore, I have no "ideal" formula to work out the problem. Is kinetic friction and "ideal" frictional force? Is static friction an "ideal" frictional force? How large is this "ideal" frictional force?
And how did you calculate these numbers for work and entropy?
The reversible value is different from the value that I calculated. However, I suspect that one of us made an arithmetic mistake. I would certainly like to compare your method for calculating the change in entropy for a reversible expansion to my method. My value, once again, was -1.07×10^5 Joules.
Now here is something I can't grasp. Without knowing the frictional forces, or whatever process makes it irreversible, how can you calculate the loss in energy?
No. I would be interested in your explanation, though.
  • #41
Sorry you are right I omitted the initial temperature of zero ° C, but specified the volume.
adiabatic reversible expansion
[tex]\begin{array}{l}
\gamma = \frac{{{C_p}}}{{{C_v}}} = \frac{{\frac{3}{2}R + R}}{{\frac{3}{2}R}} = \frac{5}{3} \\
{V_2} = {\left( {\frac{{{P_1}}}{{{P_2}}}} \right)^{{\gamma ^{ - 1}}}}{V_1} = 39.81litres \\
{T_2} = \frac{{nR}}{{{P_2}{V_2}}} = 108.8^\circ K \\
\end{array}[/tex]
First law, q = 0 , ΔU = w
[tex]w = \Delta U = n{C_v}\Delta T = n\frac{{3R}}{2}\Delta T = 9141J[/tex]
  • #42
\end{array}[/tex]
Okay, it was my error. I forgot the exact formula for an adiabatic expansion.
γ=5/3, not 3/2.
Okay, you calculated the change in energy correctly for the reversible reaction. Since you wrote q=0, I take it you also calculated the change in entropy for a reversible process correctly (ΔS=0).
I still don't get how you were able to get a precise value for work in the case of an irreversible process. Irreversibility is graded. There can't be one value of anything for a irreversible reaction.
  • #43
irreversible adiabatic
As before q=0, hence ΔU=w
and also for an expansion at constant pressure w = -pΔV
[tex] + w = \Delta U = n{C_v}\Delta T[/tex]
and
[tex] - w = {P_2}({V_2} - {V_1}) = {P_2}\left( {\frac{{nR{T_2}}}{{{P_2}}} - \frac{{nR{T_1}}}{{{P_1}}}} \right)[/tex]
equating work expressions and solving for T2
T2 = 174.8°K
Substitute back into gives the work as
5474J
I will have to sign off now for a couple of hours.
