How do you calculate the energy delivered by a capacitor
In summary, this conversation discusses how to solve for work done in solving for power when dealing with a power supply and a capacitor. The energy delivered by the power supply is QV, and the work done is simply Q.
sefsybabe
a capacitor of capacitance 10μF is fully charged to form a 20v d.c supply
1) calculate the charge stored by the capacitor
2) calculate the energy delivered by the 20v supply
1/2 cv2
1) q =cv
Q= 2x10-4
i don't know how to solve the second one pls
You wrote ## \frac{1}{2}C V^2 ## without an equal sign, check in your notes what's that equal to.
That equation relates C, V with something that may be interesting for you
sorry the equation is
W=1/2 CV2
where W=work done
Assumineg a stiff power supply with very low source resistance and a very large filter capacitor on the output, the energy that goes to charge the cap is QV, where Q=CV is the charge that rises through the supply through a fixed V=20volts during the near-instantaneous charging.
This energy expression QV=CV**2 is based on the definition of charge, voltage, and capacitance.
Of course, the final energy that's stored on the C=10uF capacitor is 0.5CV**2, the remainder of the charging energy having gone to series resistance, radiation, and ?
sefsybabe said:
W=1/2 CV2
where W=work done
work is energy
so is it power I am going to solve for??
Treat yourself to a nice schematic diagram, with the fixed-voltage supply in series with a switch and the cap.
Since you are assuming a stiff supply, all the charge is lifted through the supply at a constant voltage, so it's [(joules/coulomb)*coulomb] to get energy. Am an EE here, so most all my charge is positive and flows out of the supply into the cap.
You do not need to think about power, just energy.
Not sure if I can invoke the fact that you have a conservative field here so that the work done on a charge moving from the negative supply terminal, through the supply, to the positive supply terminal only depends on the (constant) potential difference.
Anyway, I believe you can make this a simple problem by saying the energy delivered by the supply is QV.
thank you
FAQ: How do you calculate the energy delivered by a capacitor
1. How do you calculate the energy delivered by a capacitor?
The energy delivered by a capacitor can be calculated using the formula E = 1/2 * C * V^2, where E is the energy in joules, C is the capacitance in farads, and V is the voltage in volts.
2. What is the unit of measurement for energy delivered by a capacitor?
The unit of measurement for energy delivered by a capacitor is joules (J).
3. Can the energy delivered by a capacitor be negative?
No, the energy delivered by a capacitor cannot be negative. The energy delivered by a capacitor is always positive, as it is stored in the electric field between the capacitor's plates.
4. Are there any other factors that affect the energy delivered by a capacitor?
Yes, in addition to capacitance and voltage, the energy delivered by a capacitor can also be affected by the type of dielectric material used between the plates, the distance between the plates, and the temperature.
5. How can the energy delivered by a capacitor be increased?
The energy delivered by a capacitor can be increased by increasing the capacitance or the voltage. This can be achieved by using capacitors with larger surface areas, increasing the distance between the plates, or using a higher voltage source.
