MHB How Do You Calculate the Entry Velocity of a Ball into a Basketball Hoop?
  • Thread starter Thread starter Mango12
    Ball Velocity
To calculate the entry velocity of a ball into a basketball hoop, the initial conditions include a starting velocity of 7.67 m/s, a maximum height of 4 m, and the hoop height at 3 m, with the ball starting 2.1 m above the ground. The expected entry velocity is -6.42 m/s at an angle of -43.6 degrees. The user initially struggled with the equation v^2=vo^2+2a(delta x) but eventually found a solution. The discussion highlights the importance of understanding projectile motion and the correct application of kinematic equations. The problem was ultimately resolved, confirming the user's successful calculation.
Mango12
I am trying to find the velocity at which a ball enters a basketball hoop. The answer should be -6.42m/s at an angle of -43.6 degrees, but idk how to get that.
The ball starts at a velocity of 7.67m/s and reaches a max height of 4m. The hoop is 3m high, and the ball starts 2.1m above the ground. Can anyone please help.
I tried doing v^2=vo^2+2a(delta x) but I didn't get the right answer...help please!
Mathematics news on Phys.org
Hi Mango12,
I noticed you have the [SOLVED] tag in your title, but just to make sure, have you solved this problem entirely? Or did you figure out how to do it?
Euge said:
Hi Mango12,
I figured out how to do it. But thank you for checking!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
