How Do You Calculate the Floor of 2√xn for the Given Sequence?
  • MHB
  • Thread starter anemone
  • Tags
    2015
In summary, the process for finding the floor of 2√xn involves taking the square root of xn, multiplying it by 2, and then rounding down to the nearest integer. This integer has significance in various mathematical and scientific calculations, and it will always be an integer. While there are alternative methods for finding the floor of 2√xn, the most common and simple method is the one mentioned previously. This concept can be applied in fields such as computer science, engineering, and economics, for tasks such as determining the minimum number of steps in a problem or the maximum number of combinations in a coding algorithm.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Find \(\displaystyle \left\lfloor{2\sqrt{x_n}}\right\rfloor\) given \(\displaystyle x_n=10^{2n}-10^n+1\) for all \(\displaystyle n\in N\).
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution:):
1. kaliprasad
2. lfdahl
Solution from kaliprasad:
We have
$x_n = 10^{2n} - 10^n + 1= (10^n - \frac{1}{2})^2 + \frac{3}{4}$
$ (10^n - \frac{1}{2}) \lt \sqrt{x_n} \lt 10^n$
i.e.
$ (2 * 10^n - 1) \lt 2 \sqrt{x_n} \lt 2* 10^n$
hence the given expression
$\lfloor 2 \sqrt{x_n} \rfloor = 2* 10^n-1$
FAQ: How Do You Calculate the Floor of 2√xn for the Given Sequence?
How do I find the floor of 2√xn given a sequence of numbers?
The process for finding the floor of 2√xn involves taking the square root of xn, multiplying it by 2, and then rounding down to the nearest integer. This integer is the floor of 2√xn.
What is the significance of finding the floor of 2√xn?
Finding the floor of 2√xn can be useful in various mathematical and scientific calculations, such as determining the maximum number of possible combinations or the minimum number of steps in a problem.
Can the floor of 2√xn be a decimal or fraction?
No, the floor of 2√xn will always be an integer because it is rounded down to the nearest whole number.
Are there any alternative methods for finding the floor of 2√xn?
There are other methods for finding the floor of 2√xn, such as using a calculator or programming it into a computer algorithm. However, the process of taking the square root, multiplying by 2, and rounding down is the most common and simple method.
How can I apply the concept of finding the floor of 2√xn in real life situations?
The concept of finding the floor of 2√xn can be applied in various fields, such as computer science, engineering, and economics. For example, it can be used to calculate the minimum number of steps in an optimization problem or to determine the maximum possible number of combinations in a coding algorithm.
