How Do You Calculate the Gravitational Force in a Hydrogen Atom?
In summary, an electron and a proton are 1.0x10^-10m apart. The force of attraction between the two particles is 9.11*10^31kg.
xArashix
In a hydrogen atom a electron and a proton are 1.0 x 10^-10m apart. What is the force of attraction between the two particles?
F=G m1 m2/r^2
electron: 9.11 * 10^31kg
Proton: 1.67 * 10^-27kg
so, Fgrav= (9.11 * 10^31kg) * (1.67 * 10^-27kg) / (1.0* 10^-10m)^2
Is this right?? And well if it is or if it isn't...how do u solve this?? I'm looking at this big equation and i don't know where to start. How do u multiply this and divide it?? I see many example problems like these and i see them going this far but them i lose them when they get the solution...how DO you get the solution??
you missed out the gravitational constant G = (6.67*10^-11)
Fgrav = (G*m1*m2)/(r^2)
multiply the numerator together first and divide it by the denominator.
so it's... F= (6.67*10^-11)*(9.11 * 10^31kg) * (1.67 * 10^-27kg) / (1.0* 10^-10m)^2??
xArashix said:
oh wow, so it's... F= (G*m1*m2)/(r^2)*(9.11 * 10^31kg) * (1.67 * 10^-27kg) / (1.0* 10^-10m)^2
Nope, its..
the formula is : F= (G*m1*m2)/(r^2)
so for this particular question, you need to substitute in the respective numbers..
G=(6.67*10^-11)
m1= (9.11 * 10^31kg)
m2= (1.67 * 10^-27kg)
r= (1.0* 10^-10m)
so you will get this:
F= (6.67*10^-11)(9.11 * 10^31kg)(1.67 * 10^-27kg) / (1.0* 10^-10m)^2
solve this with a calculator=)
yes that's correct
solving it with the calculator is the problem T-T...how in the world do i type that in? I feel really stupid lol...how do u multiply the 10^11 and the others..I'm lost. And i bet once i figure this out I am going to feel soooo dumb :( you can't type that whole equation in the calculator so..i don't know ;_;
u need to be using a scientific calculator or a graphic calculator in order to type "10^11" are you using a scientific calculator?
and you don't have to type in the whole string of numbers in one go.
you might like to find (6.67*10^-11)*(9.11 * 10^31kg) * (1.67 * 10^-27kg) first.. followed by (1.0* 10^-10m)^2 then divide the first answer by the second answer.
yes i do which is making me feel a lot dumber lol
if i type (6.67*10^-11)*(9.11 * 10^31kg) * (1.67 * 10^-27kg)...i get 1.01475379E-5 o_O...that's not right is it?
pardon me for not spotting this mistake earlier on, you mentioned you are using electrons, so the mass on electron is 9.11*10^-31 kg NOT 9.11*10^31, you missed out a negative sign. try recalculating =)
if an electron is 9.11*10^31kg in mass, its heavier than the sun! lol!
...WOW XD I am dumb lol thanks ^^
FAQ: How Do You Calculate the Gravitational Force in a Hydrogen Atom?
What is the force of gravitation?
The force of gravitation, also known as gravity, is the natural phenomenon by which all objects with mass are brought towards each other. This force is responsible for the motion of planets, stars, and other celestial bodies in the universe.
How is the force of gravitation calculated?
The force of gravitation is calculated using Newton's law of universal gravitation, which states that the force between two objects is directly proportional to the product of their masses and inversely proportional to the square of the distance between them.
What factors affect the force of gravitation?
The force of gravitation is affected by two main factors: the masses of the objects and the distance between them. The greater the masses of the objects, the stronger the force of gravitation. Similarly, the closer the objects are, the stronger the force of gravitation.
How does the force of gravitation affect motion?
The force of gravitation is responsible for the motion of objects in orbit around each other, such as the motion of planets around the sun. It also affects the motion of objects on Earth, as it is the force that keeps us grounded and causes objects to fall towards the ground.
Can the force of gravitation be shielded or canceled?
No, the force of gravitation cannot be shielded or canceled. It is a fundamental force of nature that exists between all objects with mass. However, its effects can be counteracted by other forces, such as air resistance or the force of thrust in rockets.
