How Do You Calculate the Mass of a Car Using Force and Acceleration?
In summary, a student pushed a car with a bathroom scale between himself and the car, maintaining a constant reading of 433N. The car accelerated from rest to 18.8 km/hr in 15.9 s. Using the equations a = Delta V/Delta t and f = ma, the student determined the acceleration of the car to be 19.7m/s^2. Using the equation W=mg, the student calculated the weight of the car to be 43.06kg. However, using the corrected equation f=ma, the student determined the mass of the car to be 1318kg.
Student3.41
71
To determine the mass of a car, a student (with a friend at the wheel) pushes the car holding a bathroom scale between himself and the car. The scale maintains a constant reading of 433 N while the car accelerates on level ground. At the conclusion of the experiement, his friend reports that the car accelerated from rest to 18.8 km/hr in 15.9 s. What was the mass of the car?
a= Delta V/Delta t
f=ma
w=mg
g=9.8m/s^2
a = 18.8km/hr/15.9s ------> 313m/s/15.9s = 19.7m/s^2 - > Acceleration of car.
F=ma, since the force is constant throughout the problem I assumed acceleration was constant.
W=mg ----> 422N=m(9.8m/s^2)--> m=43.06kg, is the weight.
f=ma ---> f=(43.1kg)(19.7m/s^2) = 847N
m= 847N/9.8m/s^2 = 86.4kg... incorrect.. am i doing too much ?
You're on the right track, but I see two errors, and I'm not sure about one of your steps.
18.8 km/hr does not equal 313 m/s. Hint: how many seconds are there in one hour?
I don't know why you tried calculating the weight - or why you used 422N. I *think* you need to reread the problem, and visualize what they did with the scale, and what the 433N actually represents.
I believe your mass should equal 1318kg, yes?
Correct.
OK, got to figure out how you did this.
I fixed my stupid mistakes;
v=5.22m/s
a=5.22m/s/15.1s=0.346m/s^2
Now, M=433N/0.346m/s^2--->1251kg
The 433N represents the weight of the car? W(N)=m(kg)a(m/s^2)
"To determine the mass of a car, a student (with a friend at the wheel) pushes the car holding a bathroom scale between himself and the car."
The car isn't on top of the scale, so it's not the weight of the car. If it were the weight of the car, then we'd just divide 433N/9.81(m/s^2). It's the amount of force required to move the car. So you did it correctly this last time, but you somehow put 15.1s into your equation, as opposed to 15.9s.
Your method of using the equations for acceleration and force to determine the mass of the car is correct. However, your final calculation for the mass of the car is incorrect. This may be due to a calculation error or a rounding error. To find the correct mass, use the value for acceleration that you calculated (19.7 m/s^2) and the given force of 433 N. The mass of the car can then be found by dividing the force by the acceleration (m = F/a). This should give a mass of approximately 22 kg. It is important to double check your calculations and be careful with significant figures to ensure accurate results.
Related to How Do You Calculate the Mass of a Car Using Force and Acceleration?
What is the definition of mass?
Mass is a measure of the amount of matter in an object. It is often confused with weight, but unlike weight, mass remains constant regardless of location.
How is mass different from weight?
While mass is a measure of the amount of matter in an object, weight is a measure of the force of gravity acting on an object. Mass remains constant, but weight can change depending on the strength of gravity.
Why is it important to measure the mass of a car on a scale?
Measuring the mass of a car on a scale is important for a number of reasons. It can help determine the fuel efficiency, cargo capacity, and overall performance of the car. It is also necessary for following safety regulations and ensuring the car is not overloaded.
How do scientists measure the mass of a car on a scale?
To measure the mass of a car on a scale, scientists use a device called a scale or balance. The car is placed on top of the scale and the scale measures the force of gravity acting on the car, which is then converted into mass using a mathematical equation.
Can the mass of a car on a scale change?
The mass of a car on a scale will remain constant unless there is a change in the amount of matter in the car. This means that if the car is damaged or parts are added or removed, the mass will change. However, the weight of the car may change due to fluctuations in gravity.
