How do you calculate the pH of 35.0-mL of 0.15M acetic acid?
  • Thread starter Eclair_de_XII
  • Tags
    Acid Ph
In summary, the initial concentration of the acetic acid solution is 0.15 M and the pH is 2.78. The subsequent calculations require the use of a titration curve calculator for a more accurate pH calculation.
Eclair_de_XII
1,083
91
"A 35.0-mL sample of 0.150 M acetic acid (CH3COOH) os titrated with 0.150 M NaOH solution. Calculate the pH after the following volumes of base have been added: (a) 0 mL, (b) 17.5 mL, (c) 34.5 mL, (d) 35.0 mL, (f) 50.0 mL."
Ka = [H+][A-]/[HA]
Ka = 1.8 ⋅ 10-5
x = ½(-b ± √(b2 - 4ac)
pH = -log[H+]
pH = 2.78 (from back of book)
0.15 mol/L ⋅ 1 L/1000 mL ⋅ 35.0 mL = 5.25 ⋅ 10-3 mol HAc
1.8 ⋅ 10-5 = (x)(x)/(5.25 ⋅ 10-3 - x)
x2 + 1.8 ⋅ 10-5x - 9.45 ⋅ 10-8 = 0
x = ½(-1.8 ⋅ 10-5 ± √3.24 ⋅ 10-10 - 37.8 ⋅ 10-8)
x = 2.99 ⋅ 10-4 mol H+
[H+] = (2.99 ⋅ 10-4 mol H+)/(0.0350 L) = 8.54 ⋅ 10-3 M
-log(8.54 ⋅ 10-3) = 2.069 ≠ 2.78
This is rather an unorthodox, and thus, unreliable method of finding the initial pH of the acetic acid solution. But I couldn't find any other way to do it... Could someone tell me if I'm doing this problem right?
You can't do equilibrium calculations using Ka (which is a concentration constant) and ignoring the concentrations. Why do you convert to number of moles, instead of using concentrations throughout the calculations?
Ka = [H+][A-]/[HA]
Ka = 1.8 ⋅ 10-5
pH = -log[H+]
I don't think the approach is unorthodox except as below. I think there is only an arithmetical/algebraic mistake. Your square root is written without right bracketing and you have got wrong sign in the -4ac term. Probably you will get the right answer if you correct that.
Where it is not wrong but unorthodox is there is a bit of unnecessary calculation.
Orthodox would be to say that [H+] is very much smaller than total acid, and therefore you can approximate the denominator of your equilibrium equation by total acid concentration [HAc] = 0.15. Then your calculation reduces to taking a square root rather than solving a quadratic. Do it both ways and you will see they are close. You can if you wish, with benefit, look into the algebra and see why.
The point is this: all this family of problems (the most frequent single one on this part of this forum) are solved using a handful of principles: mass conservation, charge conservation, equilibrium laws, I think that's all... plus use of approximations. Don't think of it as Important Laws and then, oh yes, also get rough answer quicker if approximate. No, the appropriate approximations, understanding them, and how to use them and why and when and how good and sufficient they may be depending on situations, is an essential part of what you have to think about, grasp and learn!
In most cases if you have a quadratic or higher equation you have missed a possibility of approximation. (Of course if the physical nature of the problem requires it, e.g. some equilibria with two protonation etc. polynomials may be of the essence.)
I think he will not - units are wrong. Using number of moles instead of concentrations works when the volumes cancel out, like [itex]\frac {C_1}{C_2} = \frac {n_1}{n_2}[/itex], but here we have [itex]\frac {C_1^2}{C_2} = \frac {n_1^2}{V\times n_2} \neq \frac {n_1^2}{n_2}[/itex].
I admit I have not checked numbers, but the logic looks faulty.
Okay, I'll try using concentration instead of moles.
So I thought the answer was more complicated than it seemed. I just used the initial concentration, and used the "x-is-small" approximation.
1.8 ⋅ 10-5 = (x)(x)/(0.15 - x)
1.8 ⋅ 10-5 = (x)(x)/(0.15)
2.7 ⋅ 10-6 = x2
x = 0.00164
-log[H+] = 2.78
Now to figure out the rest of the problem...
Related to How do you calculate the pH of 35.0-mL of 0.15M acetic acid?
1. What is the formula for calculating pH?
The formula for calculating pH is pH = -log[H+], where [H+] represents the concentration of hydrogen ions in moles per liter.
2. How do you determine the concentration of hydrogen ions in a solution?
To determine the concentration of hydrogen ions, you can use the formula [H+] = 10^-pH, where pH is the measured pH value of the solution.
3. What is the pKa value of acetic acid?
The pKa value of acetic acid is 4.76.
4. How do you calculate the concentration of acetic acid in moles per liter?
To calculate the concentration of acetic acid, you can use the formula [acid] = [H+] * Ka, where [H+] is the concentration of hydrogen ions and Ka is the acid dissociation constant for acetic acid.
5. What is the pH of a 35.0-mL 0.15M acetic acid solution?
The pH of a 35.0-mL 0.15M acetic acid solution can be calculated by first determining the concentration of acetic acid in moles per liter, using the formula [acid] = [H+] * Ka. Then, use the formula pH = -log[H+] to calculate the pH value.
