MHB How Do You Calculate the Probability in an Exponential Distribution?
To calculate the probability for a random variable Y with an EXP(2) distribution, the cumulative distribution function (CDF) can be used. The CDF is defined as P[X ≤ x] = 1 - e^(-λx). For P(Y > 1), the calculation involves finding P(Y ≤ 1) first, which is 1 - e^(-2*1), resulting in approximately 0.8467. Consequently, P(Y > 1) is calculated as 1 - 0.8467, yielding a final probability of about 0.1353. This method effectively demonstrates the application of the CDF in determining probabilities in exponential distributions.
das1
Help?
Suppose the random variable Y has an EXP(2) distribution. What is P(Y > 1)? (Round to four decimal places as appropriate.)
Mathematics news on Phys.org
das said:
Help?
Are you allowed to use the CDF for this distribution or should you calculate this purely from the pdf? Either way you'll need to also use this fact: $$P[Y>2]=1-P[Y \le 2]$$
I don't think there are any restrictions on what functions I can or can't use
Ok, then this should be very useful. For the exponential distribution, the CDF is the following: $$P[X \le x]=1-e^{-\lambda x}$$. How can you use this to answer your question?
So would I plug in 1 for x and 2 for λ?
Then we would get 1-e^(-2*1)? Which is .8467 but we'd actually want 1-.8467 again because we're looking for P(Y > 1) right? So about .1353?
That looks good to me! (Yes)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
