MHB How Do You Calculate the Slope of a Line with Given Coordinates and Area?
  • Thread starter Thread starter mathdad
    Line Slope
The y-intercept of the line is 6, and the area of the shaded triangle formed is 72 square units. The base of the triangle, calculated from the area formula, is determined to be 12, leading to the coordinates (0, 6) and (12, 0). The slope, calculated as the change in y over the change in x, is found to be -1/2. The triangle lies in quadrant 1, confirming the negative slope of the line. The calculations and area confirm the relationship between the coordinates and the slope.
mathdad
The y-intercept of the line in the figure is 6. Find the slope of the line if the area of the shaded region is 72 square units.
A line from quadrant 2 to quadrant 1 form a right triangle that is shaded.
If the area of the shaded triangle is 72, then 6 • what = 72? The length on the x-axis must be 12.
This means the two points are (0, 6) and (12, 0).
Note: (0, 6) is the y-intercept and (12, 0) is the x-intercept.
Let m = slope.
m = (0 - 6)/(12 - 0)
m = -6/12
m = -1/2
Correct?
Mathematics news on Phys.org
It would help if we could see "Fig. 6"! I presume that you mean there is a single line passing through (0, 6) and the x-axis as some point (x, 0) for negative x. The area of the triangle formed in Quadrant 2 is "1/2 base times height", 6|x|/2= 3|x| and we are told that is 72. 3|x|= 72 so |x|= 12 and, since x is negative, x= -12 as you say. Yes, the slope is 6/(-12)= -1/2.
The triangle formed lies in quadrant 1. The right triangle is shaded. The line crosses the points (0,6) and (12,0). The line creates a negative slope.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
