MHB How Do You Calculate the Slope to Intercept a Moving Point?
  • Thread starter Thread starter AlienNova
    Slope Speed
To calculate the slope for a moving point, the standard slope formula (y2 - y1)/(x2 - x1) needs to be adapted for the moving point, referred to as point A. When point A is in motion, its position can be described using parametric equations based on its speed and direction, such as x(t) = t + c and y(t) = t + d, where c and d are the starting coordinates. The slope of the path can be determined by knowing the trajectory's slope and the initial coordinates. An example demonstrates this with a slope of 3/2 and a starting position of (3, 2), leading to specific equations for x(t) and y(t). Understanding these concepts allows for the calculation of the slope as the moving point approaches another point.
AlienNova
Sorry for the very confusing title, I couldn't think of a different way to better explain my question shortly. Also please bare with me, I find this very hard to explain.
So I'm trying to find the slope between two points when one point is moving in a set direction with a set speed. Confused? I'm not the best with words.
Okay, so normally to find the slope of two points you use the simple formula (y2 - y1)/(x2 - x1). That's the quickest way to intersect a point (Now on going to be called point A) if point A is stationary. But what if point A is moving (In a set direction, not turning)?
Say point A is a someone you want to talk to, and they're walking. When walking to them you don't walk straight at them, you walk to a point where your two paths will cross at the same time. My question is how do you find the slope you decided to walk?
Hopefully that didn't just make things more complicated to understand. Any help will be appreciated!
Mathematics news on Phys.org
You could use parametric equations, if you have enough data.
Say the slope of the path of the moving object is 1. Then
x and y coordinates, respectively. So you'd need to know
the slope of the trajectory of the moving object and the x and y
coordinates of its starting position.
Another example: Slope 3/2, (time, t, in seconds) and a starting position of (3, 2):
x(t) = 2t + 3, y(t) = 3t + 2.
For your problem you may then compute (y2 - y(t))/(x2 - x(t)).
Thank you so much, it took me a couple read throughs but I understand it now!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
