How Do You Calculate the Sum of Minimum Values in Polynomials?
  • MHB
  • Thread starter anemone
In summary, the POTW stands for "Problem of the Week" and is a weekly mathematical problem or puzzle presented by a particular organization or group. P(x) and Q(x) refer to mathematical functions or equations used to represent the problem, and their minimum values can be determined by finding the lowest point on their respective graphs or solving for the lowest possible output value. These minimum values can be negative and finding their sum is important in solving the problem and understanding the behavior of the functions involved.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Monic quadratic polynomial $P(x)$ and $Q(x)$ have the property that $P(Q(x))$ has zeros at $x=-23, -21, -17,$ and $-15$, and $Q(P(x))$ has zeros at $x=-59,-57,-51$ and $-49$.
Find the sum of the minimum values of $P(x)$ and $Q(x)$.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution!(Cool)
1. Olinguito
2. castor28
Solution from castor28:
We start by observing that the graph of the quadratic function $f(x)=x^2-2ax+b$ is a parabola (concave upwards) with an vertical symmetry axis $x=a$. Therefore, if $f(x_1)=f(x_2)$ with $x_1\ne x_2$, $x_1$ and $x_2$ are symmetrical with respect to the axis, and $x_1+x_2=a$. This is also true in particular if $x_1$ and $x_2$ are the roots of $f(x)$.
Assume that the roots of $P(x)$ are $\alpha$ and $\beta$, and that the roots of $Q(x)$ are $\gamma$ and $\delta$. We may therefore write:
\begin{align*}
P(x) &= x^2 -(\alpha+\beta)x + p\\
Q(x) &= x^2 -(\gamma+\delta)x + q
\end{align*}
The roots of $P(Q(x))$ are the values of $x$ such that $Q(x)$ is equal to a root of $P(x)$; by the remark above, the pairs of values of $x$ giving the same value of $Q(x)$ are symmetrical with respect to the axis of the graph of $Q(x)$. This means that we have $Q(-21)=Q(-17)=\alpha$ and $Q(-23)=Q(-15)=\beta$ (if $\alpha<\beta$). We also have $\gamma+\delta=-38$, and we may now write $Q(x)=x^2+38x+q$.
A similar argument shows that $P(-57)=P(-51)=\gamma$ and $P(-59)=P(-49)=\delta$. We also have $\alpha+\beta=-108$ and $P(x)=x^2+108x+p$.
We now have;
\begin{align*}
P(-51)+P(-49) &= 2p-5798 = \gamma+\delta = -38\\
Q(-17)+Q(-15) &= 2q-702=\alpha+\beta=-108
\end{align*}
giving $p=2880$ and $q=297$. The polynomials are therefore:
\begin{align*}
P(x) &= x^2 + 108x + 2880\\
Q(x) &= x^2 + 28x+297
\end{align*}
The minimum values of $P(x)$ and $Q(x)$ are $P(-54)=-36$ and $Q(-19)=-64$, respectively. The sum of these values is $\mathbf{-100}$.
FAQ: How Do You Calculate the Sum of Minimum Values in Polynomials?
What is the POTW?
The POTW stands for "Problem of the Week" and is a weekly mathematical problem presented by a scientific or educational organization.
What are P(x) and Q(x)?
P(x) and Q(x) are mathematical functions that represent a relationship between two variables, often used in statistics or data analysis.
How do I find the minimum value of a function?
To find the minimum value of a function, you can use calculus techniques such as taking the derivative and setting it equal to 0, or graph the function and identify the lowest point.
Can the sum of the minimum values of P(x) and Q(x) be negative?
Yes, the sum of the minimum values of P(x) and Q(x) can be negative if both functions have negative minimum values.
Is there a specific method for finding the minimum values of P(x) and Q(x) in the POTW?
The method for finding the minimum values of P(x) and Q(x) in the POTW may vary depending on the specific functions given in the problem. However, the general approach would be to use mathematical techniques such as graphing, calculus, or algebra to find the minimum values.
