How Do You Calculate the Sum of Specific Binomial Coefficients?
  • MHB
  • Thread starter anemone
  • Tags
    2017
In summary, a binomial coefficient is a mathematical term that represents the number of ways to choose a set of objects from a larger set without regard to the order in which the objects are chosen. The sum of binomial coefficients is a mathematical expression that represents the total number of ways to choose a set of objects from a larger set when all possible combinations are considered. It can be calculated using the formula nC0 + nC1 + nC2 + ... + nCn or 2^n. In POTW #264, it is used to calculate the total number of ways to choose a team of 3 players from a group of 10 players. Some real-life applications of the sum of binomial coefficients include calculating probabilities in
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Without using a calculator, evaluate \(\displaystyle {2000 \choose 2}+{2000 \choose 5}+{2000 \choose 8}+\cdots+{2000 \choose 2000}.\)
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to Opalg for his correct solution, which you can find below::)
[Let $\omega = e^{2\pi i/3} = -\frac12 + \frac{\sqrt3}2i.$ Then $\omega^3 = 1$ and $1+\omega + \omega^2 = 0.$
Apply the binomial formula \(\displaystyle (1+x)^{2000} = \sum_{r=0}^{2000}x^r{2000 \choose r}\) with $x=1$, $x=\omega$ and $x=\omega^2$, to get $$(1+1)^{2000} + \omega(1+\omega)^{2000}+ \omega^2(1+\omega^2)^{2000} = \sum_{r=0}^{2000}\bigl(1 + \omega^{r+1} + \omega^{2r+2}\bigr) {2000 \choose r}.\qquad(*)$$ On the right side of that equation, if $r$ is a multiple of $3$, say $r=3k$, then $$1 + \omega^{r+1} + \omega^{2r+2} = 1 + \omega^{3k+1} + \omega^{6k+2} = 1+\omega + \omega^2 = 0.$$ If $r = 3k+1$ then $$1 + \omega^{r+1} + \omega^{2r+2} = 1 + \omega^{3k+2} + \omega^{6k+4} = 1 + \omega^2 +\omega = 0.$$ If $r = 3k+2$ then $$1 + \omega^{r+1} + \omega^{2r+2} = 1 + \omega^{3k+3} + \omega^{6k+6} = 1 + 1 + 1 = 3.$$ Therefore all the terms in the starred equation vanish except for those where $r$ is a multiple of $3$ plus $2$.
On the left side of the starred equation, $(1+1)^{2000} = 2^{2000}$.
Next, $\omega(1+\omega)^{2000} = \omega(-\omega^2)^{2000} = (-1)^{2000}\omega^{4001} = \omega^2$ (since $4001 = 3\times1333 + 2$).
Similarly, $\omega^2(1+\omega^2)^{2000} = \omega^2(-\omega)^{2000} = \omega^{2002} = \omega.$
Therefore (*) becomes $$2^{2000} + \omega^2 + \omega = 3\biggl({2000 \choose 2}+{2000 \choose 5}+{2000 \choose 8}+\ldots+{2000 \choose 2000}\biggr),$$ and since $\omega^2 + \omega = -1$ we can conclude that $${2000 \choose 2}+{2000 \choose 5}+{2000 \choose 8}+\ldots+{2000 \choose 2000} = \frac{2^{2000} - 1}3.$$
FAQ: How Do You Calculate the Sum of Specific Binomial Coefficients?
What is a binomial coefficient?
A binomial coefficient, also known as a combination, is a mathematical term that represents the number of ways to choose a set of objects from a larger set without regard to the order in which the objects are chosen.
What is the sum of binomial coefficients?
The sum of binomial coefficients is a mathematical expression that represents the total number of ways to choose a set of objects from a larger set when all possible combinations are considered. It is often used in probability and statistics to calculate the likelihood of certain outcomes.
How is the sum of binomial coefficients calculated?
The sum of binomial coefficients can be calculated using the formula nC0 + nC1 + nC2 + ... + nCn, where n is the number of objects in the larger set and nCr represents the number of ways to choose r objects from n objects. This formula can also be written as 2^n, where n is the number of objects in the set.
How is the sum of binomial coefficients used in POTW #264?
In POTW #264, the sum of binomial coefficients is used to calculate the total number of ways to choose a team of 3 players from a group of 10 players. This calculation is then used to determine the probability of choosing a specific combination of players for the team.
What are some real-life applications of the sum of binomial coefficients?
The sum of binomial coefficients has many real-life applications, including calculating the probability of certain outcomes in games of chance, predicting the likelihood of genetic traits in offspring, and determining the number of ways to arrange objects in a set. It is also used in computer science and data analysis for tasks such as feature selection and pattern recognition.
