RU2490
- 4
A block of mass m1 = 2kg and a block of mass m2 = 6kg are connected by a massless string over a pulley in the shape of a solid disk having radius R = 0.250m and M = 10kg. The fixed, wedge-shaped ramp makes an angle of 30 degrees. Coefficient of kinetic friction is .360 for both blocks. Find acceleration of the two blocks.
http://img685.imageshack.us/i/img0230oo.jpg/
Net torque = I alpha
F = ma
I= 1/2 mr^2
a =r alpha
I isolated the objects (3)
equation for object 1
T1-ukm1g= m1a
m1g-FN= 0
equation for object 2
m2gsintheta - T2ukm2gcostheta = m2a
FN-m2gcostheta = 0
TORQUE equation for disk
T2 R sintheta - T1 R sintheta = I alpha
I of a disk is 1/2 Mr^2 and i can also rewrite alpha as a/r so
T2 R sintheta - T1R sintheta = 1/2 Mr^2 a/r
all the R's cancel each other and theta is 90 so.
T2 - T1 = 1/2MaWhen i set all the three equation together i got the right answer of .31 m/s^2. My question is though, for the TORQUE equation of the disk why is it
T2R sin theta - T1R sin Theta = I alpha instead of
T1R sin theta - T2R sin theta - I alpha?
I don't believe it is because the system is accelerating down towards the second object since the 2nd object is heavier than the 1st(i know this is true for my force equation) Doesn't force have nothing to do with direction of torque? If you have a pulley system with two objects hanging on the sides for example.
If I call the mass on the left m1 and right m2. Is the net torque always going to be TR of right object - TR of left object? does it matter which object is heavier? this doesn't seem right.
The left object is making the disc rotate counter clock wise while the right object rotates the disk clockwise so why is it NOT TR of left object - TR of right object? isn't clockwise negative and counterclockwise positive?
also is theta always going to be 90 in case of a pulley system? since the disk has to spin so it has to be 90?
THANK YOU.
