How do you construct a field with 27 elements?
  • MHB
  • Thread starter Chris L T521
In summary, a field is a mathematical structure defined by a set of elements and two operations, addition and multiplication, that follow specific properties. The cardinality, or size, of a field with 27 elements is 27, and to construct such a field, a prime number must be found and a set of elements using the integers 0 to 26 must be created. The additive and multiplicative identities in a field with 27 elements are 0 and 1, respectively. The inverse of an element in a field with 27 elements is the element that, when added or multiplied with the original element, results in the additive or multiplicative identity.
Chris L T521
MHB
915
Thanks to those who participated in last week's POTW! Here's this week's problem!
Problem: Let $D$ be an integral domain. A polynomial $f(x)$ from $D[x]$ that is neither the zero polynomial nor a unit in $D[x]$ is said to be irreducible over $D$ if, whenever $f(x)$ is expressed as a product $f(x)=g(x)h(x)$, with $g(x),h(x)\in D[x]$, then $g(x)$ or $h(x)$ is a unit in $D[x]$.
(a) Suppose that $f(x)\in\mathbb{Z}_p[x]$ and is irreducible over $\mathbb{Z}_p$, where $p$ is prime. If $\deg f(x)=n$, prove that $\mathbb{Z}_p[X]/\langle f(x)\rangle$ is a field with $p^n$ elements.
(b) Construct a field with 27 elements.
This week's question was correctly answered by Sudharaka. You can find his solution below.
Theorem 1: Let \(F[x]\) be a polynomial field. An ideal \(\langle p(x)\rangle\neq\{0\}\) of \(F[x]\) is maximal if and only if \(p(x)\) is irreducible over \(F\).
(Reference: Theorem 31.6, A First Course in Abstract Algebra by J.B.Fraleigh, 3rd Edition, Page 282)Theorem 2: Let \(R\) be a commutative ring with unity. Then \(M\) is a maximal ideal of R if and only if \(R/M\) is a field.(Reference: Theorem 29.4, A First Course in Abstract Algebra by J.B.Fraleigh, 3rd Edition, Page 257)It is given that \(f(x)\) is irreducible over the field \(\mathbb{Z}_p\). Therefore by Theorem 1 it follows that, \(\langle f(x)\rangle\) is a maximal ideal of \(\mathbb{Z}_p[x]\). Then by Theorem 2 it follows that \(\displaystyle\frac{\mathbb{Z}_p[X]}{\langle f(x)\rangle}\) is a field.Take any element \(\displaystyle g(x)+\langle f(x)\rangle\in\frac{\mathbb{Z}_p[X]}{\langle f(x)\rangle}\) where \(\deg g(x)=m\). By the division algorithm for polynomial fields there exist polynomials \(h(x)\) and \(r(x)\) in \(\mathbb{Z}_p[X]\) such that,\[g(x)=f(x)h(x)+r(x)\mbox{ where }\deg r(x)<\deg f(x)=n\]\[\therefore g(x)+\langle f(x)\rangle=f(x)h(x)+r(x)+\langle f(x)\rangle\]But, \(f(x)h(x)\in\langle f(x)\rangle\). Therefore,\[g(x)+\langle f(x)\rangle=r(x)+\langle f(x)\rangle\mbox{ where }\deg r(x)<n\]\[\therefore g(x)+\langle f(x)\rangle=a_{n-1}x^{n-1}+a_{n-2}x^{n-2}+\cdots+a_{1}x+a_{0}+\langle f(x)\rangle\]For each \(a_{i}\mbox{ where }i=\{0,1,\cdots,n-1\}\) there are \(\left|\mathbb{Z}_{p}\right|=p\) choices to choose from. Therefore,\[\left|\frac{\mathbb{Z}_p[X]}{\langle f(x)\rangle}\right|=p^{n}\]Q.E.DLet \(f(x)=x^3\) and \(p=3\). Then the field \(\displaystyle\frac{\mathbb{Z}_{3}[X]}{\langle x^3\rangle}\) has \(3^3=27\) elements.
FAQ: How do you construct a field with 27 elements?
1) How do you define a field?
A field is a mathematical structure that is defined by a set of elements and two operations, addition and multiplication. These operations must follow certain properties such as closure, commutativity, associativity, and distributivity.
2) What is the cardinality of a field with 27 elements?
The cardinality, or size, of a field with 27 elements is 27. This means that there are 27 unique elements in the field.
3) How do you construct a field with 27 elements?
To construct a field with 27 elements, we first need to find a prime number, p, such that p^3 = 27. In this case, p = 3. Next, we create a set of elements using the integers 0 to 26. The operations of addition and multiplication are defined modularly, where any result greater than 26 is reduced by subtracting 27. This set with the defined operations forms a field with 27 elements.
4) What are the additive and multiplicative identities in a field with 27 elements?
The additive identity is 0, as 0 + a = a for any element a in the field. The multiplicative identity is 1, as 1 * a = a for any element a in the field.
5) What is the inverse of an element in a field with 27 elements?
The inverse of an element a in a field with 27 elements is the element b, such that a + b = 0 and a * b = 1. In other words, the inverse of an element is the element that, when added or multiplied with the original element, results in the additive or multiplicative identity, respectively.
