How Do You Convert a Trigonometric Expression into a Sine Equation Form?
In the given equation, the cosine term has a negative coefficient while the sine term has a positive coefficient. This means that the cosine term will have to be converted to a sine term with a positive coefficient, while the sine term will be left as is. Does that make sense?
karush
MHB
3,269
$$-2 \sqrt{3}\cos\left({\theta}\right)+6\sin\left({\theta}\right) $$
Convert to
$$A\sin\left({B\left[\theta-C\right]}\right)+D$$
I couldn't find an example how to do this coversion
Mathematics news on Phys.org
Convert to
I would recommend switching to a single cosine first, then use an angular shift to get the sine. Does that help?
Do you know that cosine and sine are $\dfrac{\pi}{2}$ (or 90 degrees) out-of-phase?
$$a\cos\left({\theta}\right)+b\sin\left({\theta}\right)=R\cos\left({\theta-\alpha}\right)$$
Right. So you can find $R$ and $\alpha$ from the usual rectangular-to-polar equations. Then, if you recall that $\sin(\theta+\pi/2)=\cos(\theta)$, as Deveno mentioned earlier, you can finish.
$$R=4\sqrt{3}$$
$$ \alpha=\frac{2\pi}{3}$$
$$4\sqrt{3}\sin\left({\theta}-\frac{\pi}{6}\right)$$
Alternatively,
\(\displaystyle 6\sin x-2\sqrt3\cos x=c\sin(x+d)\)
\(\displaystyle c\sin\left(\frac{\pi}{2}+d\right)=6\)
\(\displaystyle c\sin(\pi+d)=2\sqrt3\)
\(\displaystyle c\cos d=6\)
\(\displaystyle c\sin d=-2\sqrt3\)
\(\displaystyle \tan d=-\frac{1}{\sqrt3}\Rightarrow d=-\frac{\pi}{6}\)
\(\displaystyle c\sin\left(\frac{\pi}{2}-\frac{\pi}{6}\right)=6\Rightarrow c=4\sqrt3\)
\(\displaystyle 6\sin x-2\sqrt3\cos x=4\sqrt3\sin\left(x-\frac{\pi}{6}\right)\)
Well that save $\cos\left({\theta}\right)$ to
$\sin\left({\theta}\right)$ conversion
How do know to use + or -. :cool:
Can you be more specific?
FAQ: How Do You Convert a Trigonometric Expression into a Sine Equation Form?
What is the purpose of converting an equation to sin x?
The purpose of converting an equation to sin x is to express the equation in terms of the sine function. This allows for easier manipulation and analysis of the equation, especially when dealing with trigonometric identities and equations.
How do you convert an equation to sin x?
To convert an equation to sin x, first identify any trigonometric functions (such as cosine, tangent, etc.) in the equation. Then, use trigonometric identities and algebraic manipulation to rewrite the equation in terms of the sine function.
What are some common trigonometric identities used in converting to sin x?
Some common trigonometric identities used in converting to sin x include the Pythagorean identities (sin^2x + cos^2x = 1), the double angle identities (sin2x = 2sinx cosx), and the sum and difference identities (sin(x+y) = sinxcosy + cosxsiny).
Why is it important to convert an equation to sin x?
Converting an equation to sin x can make it easier to solve and manipulate, especially when dealing with trigonometric identities and equations. It also allows for a more visual representation of the equation, as the sine function is often graphed and studied in mathematics.
Are there any limitations to converting an equation to sin x?
Yes, there may be limitations to converting an equation to sin x. For example, some equations may not have an equivalent form in terms of the sine function. Additionally, the process of converting to sin x may introduce extraneous solutions, so it is important to check the validity of the solutions obtained.
