jim1174
- 79
As an example let's say The diameter is 28' 4" how do you convert into inches and to feet
1 ft = 12"jim1174 said:As an example let's say The diameter is 28' 4" how do you convert into inches and to feet
I gave you two equations - one to convert feet to inches, and the other to convert inches to feet. If you want to convert, say 8 feet to inches, just multiply both sides of the first equation by 8.jim1174 said:What is the equation I use to convert it? I tryed to google it but all I get are conversion calculaters
Convert the 28' to inches, and then add on the 4".jim1174 said:What I need to do is convert the diameter to inches then convert the diameter to feet
"It ain't rocket surgery..."jim1174 said:ok i understand it now thanks
The formula for converting Diameter to inches is: Diameter (in) = Diameter (ft) x 12.
To convert Diameter to feet, you need to divide the Diameter (in inches) by 12. This will give you the Diameter in feet.
Let's say we have a Diameter of 36 inches. To convert this to feet, we would divide 36 by 12, giving us a Diameter of 3 feet. To convert back to inches, we would multiply 3 by 12, giving us a Diameter of 36 inches again.
Diameter can be measured in various units, such as inches, feet, centimeters, or meters. It depends on the object or material being measured and the desired level of accuracy.
Yes, there are many online tools and calculators available that can easily convert Diameter to inches and feet. These tools can be found by searching for "Diameter to inches and feet converter" on a search engine.
