How Do You Determine the Degree of the Field Extension K/L in POTW #173?
  • MHB
  • Thread starter Euge
  • Tags
    2015
In summary, POTW #173 is a weekly problem-solving challenge that involves finding the solution to a specific mathematical equation. The problem for this particular week was to solve the equation 1/2 + 2/3 + 3/4 + ... + 9/10 = ? Several individuals submitted their solutions, but only one was considered the correct answer. The correct solution was 8 16/19 or 161/19, which was determined by finding the pattern in the equation. The purpose of POTW #173 was to challenge individuals to think critically and creatively, as well as provide an opportunity for them to practice problem-solving skills and share their solutions with others.
Euge
MHB
POTW Director
2,073
244
Here is this week's POTW:
Let $x$ be a variable and $K = F(x)$ the field of rational functions in $x$ over a field $F$. Let $L = F\left(\frac{f(x)}{g(x)}\right)$, where $f(x),\, g(x)\in F[x]$ are relatively prime and $\frac{f}{g}\in K\setminus F$. Show that $K/L$ is a finite extension and evaluate $[K:L]$ in terms of $f$ and $g$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
No one answered this week's problem. You can read my solution below.
Let $r = \frac{f(x)}{g(x)}$. Since $K = L(x)$ and $x$ is a root of the polynomial $q(t) := f(t) - rg(t)$, which is a polynomial over $L$, then $[K:L]$ is finite. Since $r\notin F$, $\deg q(t) = \max\{\deg f(x), \deg g(x)\}$. The claim is that $[K:L] = \max\{\deg f(x), \deg g(x)\}$. This will follow by showing that $q$ is irreducible over $L$. Since $[K:L]$ is finite and $[K:F]$ is infinite, then $[L:F]$ is infinite, so $r$ is transcendental over $F$. Hence, $F$-polynomials in variable $t$ can be identified with $F$-polynomials in $r$.
As a polynomial in $r$, $q$ is a degree one polynomial with coefficients in $F(t)$. In particular, $q$ is an element of $F(t)[r]$. So $q$ is irreducible over $F(t)$. In fact, $q$ is irreducible over $F[t]$ since it is primitive in $F[t][r]$ (as $\gcd(f(x),g(x)) = 1$) and irreducible over $F(t)$. Now as $F[r][t] = F[t][r]$, $q$ is irreducible in $F[r][t]$, and thus $q$ is irreducible over $F(r)$ , which is $L$.
FAQ: How Do You Determine the Degree of the Field Extension K/L in POTW #173?
What is POTW #173?
POTW #173 stands for "Problem of the Week #173". It is a weekly problem-solving challenge that is posted on various online platforms for individuals to solve and share their solutions.
What was the problem for POTW #173?
The problem for POTW #173 was to find the solution to a specific mathematical equation involving a sequence of numbers. The equation was: 1/2 + 2/3 + 3/4 + ... + 9/10 = ?
Did anyone solve POTW #173?
Yes, several individuals submitted their solutions for POTW #173. However, only one solution is considered the correct answer.
What was the correct solution to POTW #173?
The correct solution to POTW #173 was 8 16/19 or 161/19. This was determined by finding the pattern in the equation and solving for the remaining value.
What was the purpose of POTW #173?
The purpose of POTW #173 was to challenge individuals to think critically and creatively in solving a complex mathematical problem. It also provided an opportunity for individuals to practice problem-solving skills and share their solutions with others.
