MHB How Do You Determine the Number of Toothpicks in a Stack of Squares?
  • Thread starter Thread starter Gurtejtaggar
    Algebra
To determine the total number of toothpicks needed for a stack of squares, a quadratic function can be used based on the sequence of toothpick counts: 4, 10, 18, and 28. The first differences (6, 8, 10) indicate a constant second difference of 2, confirming a quadratic relationship. The function can be expressed as T(n) = k_1n^2 + k_2n + k_3, where the parameters k_i are derived from the given values. By solving the resulting linear system, it is found that T(n) = n^2 + 3n, which simplifies to n(n + 3). This provides a clear formula for calculating the toothpicks needed for any stack height n.
Gurtejtaggar
I am doing a problem in math which I can't seem to solve.The problem is apart of my discrete functions unit it grade 11 math. The question is: Toothpicks are used to make a sequence of stacked squares as shown. Determine a rule for calculating the total number of toothpicks needed for a stack of squares that is n high. It also gave a diagram with 4 terms and the number of toothpicks in each term was 4,10,18,28. I know that the first differences are 6,8 and 10 which means the second differences share a constant value of 2. Does this mean that I need to make a quadratic equation to find the answer or something else? If so, how would I? By the way, this problem is a thinking or extension problem.
Mathematics news on Phys.org
Your observations are correct...we can represent the total $T$ number of toothpicks for a stack $n$ levels high with the function:
$$T(n)=k_1n^2+k_2n+k_3$$
So, what you want to do is use the given values to determine the values of the parameters $k_i$.
$$T(1)=k_1+k_2+k_3=4$$
$$T(2)=4k_1+2k_2+k_3=10$$
$$T(3)=9k_1+3k_2+k_3=18$$
So, you have a linear 3X3 system to solve.
By the way, I am going to delete the duplicate of this thread posted in our "Chat Room" forum. :D
We could simplify matters by observing $T(0)=0$ and since then $k_3=0$ reduce the system to:
$$k_1+k_2=4$$
$$2k_1+k_2=5$$
Subtracting the former from the latter, we obtain:
$$k_1=1\implies k_2=3$$
And so we have:
$$T(n)=n^2+3n=n(n+3)$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
