MHB How Do You Determine the Range of the Function y = 2x/(x - 1) Through Graphing?
  • Thread starter Thread starter mathdad
To determine the range of the function y = 2x/(x - 1) through graphing, the function can be rewritten to identify its behavior. The transformation shows a horizontal asymptote at y = 2, indicating that the range excludes this value. Consequently, the range is defined as (-∞, 2) ∪ (2, ∞). The graph resembles y = 1/x, vertically stretched by a factor of 2 and shifted right and up, but these transformations do not change the overall range. Understanding these characteristics allows for accurate identification of the function's range.
mathdad
Find the range of y = 2x/(x - 1) by graphing?
What are the steps? How is this done?
Mathematics news on Phys.org
I would write:
$$y=\frac{2x}{x-1}=\frac{2x-2+2}{x-1}=\frac{2(x-1)+2}{x-1}=2+\frac{2}{x-1}$$
We see this will have a horizontal asymptote at $y=2$, and so the range must be:
$$(-\infty,2)\,\cup\,(2,\infty)$$
We know this will have a graph that is the same as $$y=\frac{1}{x}$$, but vertically stretched by a factor of 2 and translated one unit to the right, neither of which affect the range. It will also be translated 2 units up, which will affect the range by moving the horizontal asymptote up 2 units.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
