How Do You Differentiate $\frac{x \sqrt{x^2+1}}{(x+1)^{2/3}}$?
  • MHB
  • Thread starter karush
  • Tags
    Derivative
In summary, to find the derivative of $y=\frac{x \, \sqrt[]{x^2+1}}{(x+1)^{2/3}}$, we can use implicit differentiation and the properties of logarithms. We can then simplify the resulting expression to get $\frac{4x^3+6x^2+x+3}{3(x+1)^{5/3}\sqrt{x^2+1}}$ as the final answer. Alternatively, we can use the rule for implicit differentiation and simplify the expression to get the same result.
karush
MHB
3,269
$\tiny{242.2q.3}$
$\textsf{find the derivative}\\$
\begin{align}
\displaystyle
y&=\frac{x \, \sqrt[]{x^2+1}}{(x+1)^{2/3}} \\
\ln{y}&=\ln x
+ \frac{1}{2}\ln(x^2+1)
- \frac{2}{3}\ln(x+1)\\
\end{align}
$\textit{thot this would help but what next??}$
Use implicit differentiation, knowing that $\d{}{x}\ln\left({x}\right)=\frac{1}{x}$ and $\d{}{x}\ln\left({y}\right)=\frac{1}{y}\d{y}{x}$.
$\tiny{242.2q.3}$
\begin{align}
\displaystyle
\ln{y}&=\ln x
\frac{1}{y}\d{y}{x}&=\frac{1}{x}+\dfrac{x}{x^2+1}-\dfrac{2}{3\left(x+1\right)}\\
\d{y}{x}&=\frac{y}{x}+\dfrac{xy}{x^2+1}-\dfrac{2y}{3\left(x+1\right)}
\end{align}
$\displaystyle{y=\frac{x \, \sqrt[]{x^2+1}}{(x+1)^{2/3}}}$
Let $f=x \, \sqrt[]{x^2+1}$ and $g=(x+1)^{2/3}$.
Then $\displaystyle{y'=\frac{f'\cdot g-f\cdot g'}{g^2}} \ \ \ (\star)$
We have the following:
\begin{align*}f' & =(x)' \, \sqrt[]{x^2+1}+x \, (\sqrt[]{x^2+1})'= \sqrt[]{x^2+1}+x \, \frac{1}{2\sqrt[]{x^2+1}}\cdot (x^2+1)' =\sqrt[]{x^2+1}+x \, \frac{2x}{2\sqrt[]{x^2+1}} \\ &=\sqrt[]{x^2+1}+ \, \frac{x^2}{\sqrt[]{x^2+1}} =\frac{\sqrt[]{x^2+1}^2+x^2}{\sqrt[]{x^2+1}}=\frac{x^2+1+x^2}{\sqrt[]{x^2+1}}\\ &=\frac{2x^2+1}{\sqrt[]{x^2+1}}\end{align*}
$$g'=\frac{2}{3}(x+1)^{2/3-1}=\frac{2}{3}(x+1)^{-1/3}$$
$$g^2=(x+1)^{4/3}$$
So, substituting these at the relation $(\star)$ we get:
\begin{align*}y' &=\frac{\frac{2x^2+1}{\sqrt[]{x^2+1}}\cdot (x+1)^{2/3}-x \, \sqrt[]{x^2+1}\cdot \frac{2}{3}(x+1)^{-1/3}}{(x+1)^{4/3}} \\ &=\frac{\sqrt{x^2+1}\left (\frac{2x^2+1}{\sqrt[]{x^2+1}}\cdot (x+1)^{2/3}-x \, \sqrt[]{x^2+1}\cdot \frac{2}{3}(x+1)^{-1/3}\right )}{(x+1)^{4/3}\sqrt{x^2+1}} \\ &=\frac{\left (2x^2+1\right )\cdot (x+1)^{2/3}-x \, (x^2+1)\cdot \frac{2}{3}(x+1)^{-1/3}}{(x+1)^{4/3}\sqrt{x^2+1}} \\ &=\frac{(x+1)^{1/3}\left (\left (2x^2+1\right )\cdot (x+1)^{2/3}-x \, (x^2+1)\cdot \frac{2}{3}(x+1)^{-1/3}\right )}{(x+1)^{1/3}(x+1)^{4/3}\sqrt{x^2+1}} \\ &=\frac{\left (2x^2+1\right )\cdot (x+1)-x \, (x^2+1)\cdot \frac{2}{3}}{(x+1)^{5/3}\sqrt{x^2+1}} \\ & =\frac{3\left (\left (2x^2+1\right )\cdot (x+1)-x \, (x^2+1)\cdot \frac{2}{3}\right )}{3(x+1)^{5/3}\sqrt{x^2+1}} \\ &=\frac{3\left (2x^2+1\right )\cdot (x+1)-2x \, (x^2+1)}{3(x+1)^{5/3}\sqrt{x^2+1}} \\ &=\frac{3\left (2x^3+x+2x^2+1\right )-2 \, (x^3+x)}{3(x+1)^{5/3}\sqrt{x^2+1}} \\ &=\frac{6x^3+3x+6x^2+3-2x^3-2x}{3(x+1)^{5/3}\sqrt{x^2+1}} \\ &=\frac{4x^3+6x^2+x+3}{3(x+1)^{5/3}\sqrt{x^2+1}}\end{align*}
karush said:
$\tiny{242.2q.3}$
\begin{align}
\displaystyle
\ln{y}&=\ln x
\end{align}
Good job so far, now remember that you already know what y is in terms of x, so you can write the derivative completely in terms of x as well.
\begin{align}
\displaystyle
\ln{y}&=\ln x
\end{align}
$\displaystyle
y=\frac{x \, \sqrt[]{x^2+1}}{(x+1)^{2/3}} \therefore \frac{y}{x}=\frac{\sqrt[]{x^2+1}}{(x+1)^{2/3}}$
which is the first termonline calculator returned this for the answer so not sure how the 2nd term was derived the third is just 2y in numerator then simplify
$y'=\dfrac{\sqrt{x^2+1}}{\left(x+1\right)^\frac{2}{3}}
+\dfrac{x^2}{\left(x+1\right)^\frac{2}{3}\sqrt{x^2+1}}
-\dfrac{2x\sqrt{x^2+1}}{3\left(x+1\right)^\frac{5}{3}}$
karush said:
\begin{align}
\displaystyle
\ln{y}&=\ln x
\end{align}
$\displaystyle
I suppose you could do it that way, I would have just done...
$\displaystyle \begin{align*} \frac{\mathrm{d}y}{\mathrm{d}x} &= y \left[ \frac{1}{x} + \frac{x}{x^2 + 1} - \frac{2}{3 \left( x + 1 \right) } \right] \\ &= \frac{x\,\sqrt{ x^2 + 1 }}{\left( x + 1 \right) ^{\frac{2}{3}}} \left[ \frac{1}{x} + \frac{x}{x^2 + 1} - \frac{2}{3\left( x + 1 \right) } \right] \end{align*}$
well that make more semse,,
FAQ: How Do You Differentiate $\frac{x \sqrt{x^2+1}}{(x+1)^{2/3}}$?
What is a derivative?
A derivative is a mathematical concept that represents the rate of change of a function with respect to one of its variables. In other words, it shows how much a function is changing at a specific point.
How is the derivative of a function calculated?
The derivative of a function can be calculated using the limit definition or by using differentiation rules, such as the power rule, product rule, quotient rule, and chain rule.
What does "242.2q.3" represent in this equation?
"242.2q.3" is most likely a specific function or equation that needs to be differentiated. It could represent a polynomial, trigonometric, logarithmic, or exponential function.
What is the purpose of finding a derivative?
The purpose of finding a derivative is to understand the behavior of a function and its rate of change. It is also used in many applications, such as optimization, physics, and engineering.
Can the derivative of any function be calculated?
Yes, the derivative of any function can be calculated as long as the function is continuous and differentiable. Some functions may require more complex methods to find the derivative, but it is always possible to calculate it.
