How Do You Divide Rational Expressions?
  • Thread starter tikka
In summary, Tikka is having trouble understanding dividing rational expressions in math, and is looking for someone to walk them through a specific example. They also mention difficulties with formatting their expressions, and are recommended to use a program such as TexAide.
tikka
hello people. I am sorry about this post becuse i have been reading some of the posts here and they are really high lvl math. I however am only in grade 10. I am having troubles dividing rational expressions. I have missed a week or so of school and I am lost now :frown:
. i have an example here that hopefully some one can walk me step by step through it.
Thanks for your time and posts are appreciated.
EX.
x^2 - x - 20 x^2 + 9x + 20
x^2 - 6x x^2 - 12x + 36
i can't seem to get them to tay where i put them so the bold is on the right side and the normal is on the left
Mathematics news on Phys.org
EX.
I have trouble understanding what your expressions mean. However, the general idea of dividing a polynomial by another polynomial is very much like doing long division.
For example (assuming you want (x^2 - x - 20)/(x^2 - 6x)) first look at the highest degree terms in the numerator and the divisor and divide. In this case it is 1. Then multiply the divisor by the trial quotient and subtract from the numerator to get the next trial numerator. Keep going until the trial numerator is of lower degree than the divisor. This last trial numerator is the remainder. In this example, the quotient is 1 and the remainder is 5x - 20.
Tikka,
Learn to use tex or TexAide to write (or "type") your expressions to appear in a conventional notated form. TexAide is a free download and is easy to use.
To divide rational expressions, you use the same process as you use for numeric constants - no change. Watch this:
[tex] \[
\begin{array}{l}
\frac{{x^2 - x - 20}}{{x^2 - 6x}} \div \frac{{x^2 + 9x + 20}}{{x^2 - 12x + 36}} \\
\frac{{x^2 - x - 20}}{{x^2 - 6x}} \bullet \frac{{x^2 - 12x + 36}}{{x^2 + 9x + 20}} \\
\frac{{(x - 5)(x + 4)}}{{x(x - 6)}} \bullet \frac{{(x - 6)(x - 6)}}{{(x + 4)(x + 5)}} \\
\end{array}
[/tex]
You see, back factoring any factorable expressions, here you find simplification is possible, or hopefully, helpful.
Then you obtain:
[tex] \[
\frac{{(x - 5)(x - 6)}}{{x(x + 5)}} = \frac{{x^2 - 11x + 30}}{{x^2 + 5x}}
[/tex]
Can you take it from there, or still need help? You want to use the expression on the right side, since it is simplified and in a good multiplied form (general forrm).
FAQ: How Do You Divide Rational Expressions?
What is a rational expression?
A rational expression is an expression that is written as a fraction with polynomials in the numerator and denominator. It can also be described as a fraction with variables in the numerator and denominator.
How do I simplify a rational expression?
To simplify a rational expression, factor the numerator and denominator and then cancel out any common factors. If there are no common factors, multiply the numerator and denominator by 1 in the form of a fraction with the denominator as the LCD (lowest common denominator).
Can a rational expression have a variable in the denominator?
Yes, a rational expression can have a variable in the denominator. However, it is important to note that the expression must have a non-zero value in the denominator for it to be defined.
How do I add or subtract rational expressions?
To add or subtract rational expressions, first find the LCD of the expressions. Then, multiply each term by the appropriate form of 1 so that the denominator becomes the LCD. Finally, combine like terms in the numerator and simplify if possible.
Can a rational expression have a negative exponent?
Yes, a rational expression can have a negative exponent. A negative exponent indicates that the term is in the denominator, so it can be rewritten as a positive exponent in the numerator by moving it to the opposite location in the fraction.
