How do you DO analytic continuation?
In summary, the conversation discusses the concept of analytic continuation and how to perform it on a function. The method used depends on the specific function and can involve finding series expansions and derivatives. In simpler cases, one can use the operator form to find the series expansion and use it to find the function and its derivatives at a different point. An example is given for finding an expansion of 1/(1-x) about two different points.
lolgarithms
120
they talk about the existence of analytic continuation, but how do you find (the power series/product), calculate, compute the analytic continuation? how do you actually do analytic continuation on a function?
That depends strongly on the specific function involved.
i mean, when you do not have a function whose Taylor series converge to it everywhere, how do you find the analytic continuation?
One could write ten books about this. Often analytic continuation is not practical. The method ones uses differers greatly with the specific problem.
In very simple cases the following works
1) find the series expansion of f and a number of derivatives
f(z+h)=f(z)+f'(z)h+f''(x)h^2+...
f'(z+h)=f'(z)+f''(z)h+f'''(x)h^2+...
f''(z+h)=f''(z)+f'''(z)h+f''''(x)h^2+...
f'''(z+h)=f'''(z)+f'(z)h+f'''''(x)h^2+...
in operator form
f(z+h)=exp(hD)f(z)
f'(z+h)=exp(hD)f'(z)
[D^n]f(z+h)=exp(hD)[D^n]f(z)
find a series for f about z=a
given f and derivatives at z=a
use the series to find f and derivatives at z=b
find a new series for f about z=b
now you can find f and derivatives at z=c where c can be found by expansion about b, but not expansion about a
hopefully this is enough but if not repeat more times
example
f=1/(1-x)
find an expansion of f about z=0 (radius=1)
find an expansion about z=-sqrt(2)/2 (radius=1+sqrt(2)/2)
compute f for some z such that |z+sqrt(2)/2|<1+sqrt(2)/2 (ie z=-2)
have fun!
FAQ: How do you DO analytic continuation?
What is analytic continuation?
Analytic continuation is a mathematical technique used to extend the domain of definition of a complex-valued function. It allows the function to be defined and evaluated in regions where it would not otherwise be defined.
Why is analytic continuation important?
Analytic continuation is important because it allows us to study functions in complex analysis, which has many applications in physics, engineering, and other fields. It also helps us understand the behavior of functions at points where they are not defined.
How do you perform analytic continuation?
To perform analytic continuation, you must first have a function that is analytic (i.e. smooth and without singularities) in a region. Then, you use known properties and relationships of the function to extend its domain of definition to other regions.
What are the challenges of analytic continuation?
One of the main challenges of analytic continuation is that it is not always possible to extend a function in a unique way. Different techniques and approaches may lead to different continuations, and determining which one is the most appropriate or useful can be a difficult task.
What are some applications of analytic continuation?
Analytic continuation has many applications in physics, engineering, and other fields. It is used in the study of complex systems, such as fluid dynamics and electromagnetism. It also has applications in number theory, where it is used to study the distribution of prime numbers.
