How Do You Evaluate This Limit Using a Definite Integral?
In summary, the problem is to evaluate the limit of an integral. The attempt involved using a series expansion and making a substitution, but the person was unsure how to proceed. Two solutions were suggested: bringing the limit inside the integral and using integration by parts. Both solutions led to the answer of 1/2.
Saitama
4,243
93
Problem:
Evaluate:
$$\lim_{n\rightarrow \infty}\int_0^1 \frac{nx^{n-1}}{1+x}\,dx$$
Attempt:
I used the series expansion:
$$\frac{1}{1+x}=\sum_{r=0}^{\infty} (-1)^rx^r$$
From above, I got:
$$\lim_{n\rightarrow \infty} \sum_{r=0}^{\infty} \frac{(-1)^rn}{n+r}$$
But I don't see how to proceed from here. :confused:
Is there a way to solve this by elementary methods? I ask this because when I enter the above limit in W|A, it shows me weird things.
Any help is appreciated. Thanks!
You could make the substitution $u = x^{n}$ and then justify bringing the limit inside of the integral. Doing so you'll see that the answer is $\frac{1}{2}$.
Pranav said:
Problem:
Evaluate:
Integrate by parts: \(\displaystyle \int_0^1\frac{nx^{n-1}}{1+x}\,dx = \Bigl[\dfrac{x^n}{1+x}\Bigr]_0^1 + \int_0^1\dfrac{x^n}{(1+x)^2}\,dx.\) But $\dfrac{x^n}{(1+x)^2} < x^n$ when $x > 0$, so that \(\displaystyle \int_0^1\dfrac{x^n}{(1+x)^2}\,dx < \int_0^1 x^n\,dx \to0\) as $n\to\infty$. That will quickly lead to RV's answer $\frac12.$
Ah, I never thought of it, thanks a lot Random Variable.
This is a very nice solution, thank you Opalg! :)
FAQ: How Do You Evaluate This Limit Using a Definite Integral?
What is a limit with a definite integral?
A limit with a definite integral is a mathematical concept used to describe the behavior of a function as the input approaches a specific value. It is represented by the notation "lim x→a f(x) = L", where "a" is the value that the input is approaching and "L" is the limit value.
How is a limit with a definite integral calculated?
A limit with a definite integral can be calculated using the fundamental theorem of calculus. This involves finding the antiderivative of the function and evaluating it at the two limits of integration, then subtracting the two values.
What is the difference between a limit with a definite integral and a regular limit?
The main difference between a limit with a definite integral and a regular limit is that the definite integral takes into account the entire area under the curve of a function, while a regular limit only considers the behavior of the function at a specific point.
Why is a limit with a definite integral important in mathematics?
A limit with a definite integral is important in mathematics because it allows us to calculate the area under a curve, which has many real-world applications. It also allows us to better understand the behavior of a function and make predictions about its values at certain points.
Can a limit with a definite integral be negative?
Yes, a limit with a definite integral can be negative. This occurs when the area under a curve is below the x-axis, resulting in a negative value for the definite integral. It is important to pay attention to the sign of the limit with a definite integral when interpreting its meaning.
