How Do You Evaluate ∫x²√(1-x²) dx Using Trig Substitution?
  • MHB
  • Thread starter karush
  • Tags
    Dx
In summary, the conversation discusses the process of integrating the expression $\int {x}^{2}\sqrt{1-{x}^{2 }} \ dx$ using trigonometric substitutions. It is determined that substituting $x=\sin(\theta)$ is the most appropriate approach, and the integral is simplified using double-angle identities for sine and cosine. The final solution is found to be $\frac{\arcsin\left({x}\right)}{8} - \frac{\sin\left({4\arcsin\left({x}\right)}\right)}{32}+C$.
karush
MHB
3,269
W8.3.6 evaluate
$$\int {x}^{2}\sqrt{1-{x}^{2 }} \ dx
= \arcsin\left({x}\right)/8—\sin\left({4\arcsin\left({x}\right)}\right)/32 + C $$
This is from an exercise on trig substitutions so
$$x=\sin\left({x}\right)
\text{ so }
\int\sin^2 \left({x}\right)\sqrt{1-\sin^2 \left({x}\right)}\ dx
\implies \int\sin^2 \left({x}\right) \cos\left({x}\right) \ dx
No example to follow on this so seeing if this is a good start
I would let:
\(\displaystyle x=\sin(\theta)\implies dx=\cos(\theta)\,d\theta\)
And the integral becomes:
\(\displaystyle I=\int \sin^2(\theta)\cos^2(\theta)\,d\theta\)
At this point I would look at the double-angle identity for sine...:)
$\sin\left({2x}\right)=2\sin\left({x}\right)\cos\left({x}\right)$
Then
$I=2\int\sin^2 \left({2x}\right)\ dx $
You are correct when you state:
\(\displaystyle \sin(2u)=2\sin(u)\cos(u)\)
However, this then means:
\(\displaystyle \sin(u)\cos(u)=\frac{\sin(2u)}{2}\)
And so the integral becomes:
\(\displaystyle I=\frac{1}{4}\int \sin^2(2\theta)\,d\theta\)
Now a double-angle identity for cosine can be used...the form which relates the cosine of a double-angle to a function of the square of the sine function...:)
Double angle of cosine can be used?
$$\cos\left({2\theta}\right)=1-2\sin^2 \left({\theta}\right)$$
$$\sin^2(x)=1-\cos^2(x)$$
$$2\sin^2(x)=1-\cos^2(x)+\sin^2(x)$$
$$2\sin^2(x)=1-\cos(2x)$$
$$\sin^2(x)=\dfrac{1-\cos(2x)}{2}$$
So then we would have
$$I=\frac{1}{4}\int\frac{1}{2} \ dx
- \frac{1}{4 }\int\frac{\cos\left({2x}\right)}{2} \ dx
\implies
\frac{x}{8} - \frac{\sin\left({2x}\right)}{16} + C
This doesn't look like the answer!
\implies
You have forgotten that you converted to a function of $\displaystyle \begin{align*} \theta \end{align*}$.
So from $\displaystyle \begin{align*} \frac{\theta}{8} - \frac{\sin{(2\,\theta )}}{16} + C \end{align*}$ and recalling your original substitution of $\displaystyle \begin{align*} x = \sin{(\theta)} \end{align*}$ what is the answer?
Yes, from this you get (I will use $u$ instead of $\theta$ since we are already using $\theta$):
\(\displaystyle \sin^2(u)=\frac{1-\cos(2u)}{2}\)
And so your integral then becomes:
\(\displaystyle I=\frac{1}{8}\int 1-\cos(4\theta)\,d\theta\)
earlier
$x=\sin\left({\theta}\right)$
so
$\theta = \arcsin\left({x}\right)$
Then back substittute
$\displaystyle \frac{\arcsin\left({x}\right)}{8} - \frac{\sin\left({4\arcsin\left({x}\right)}\right)}{32}+C$
FAQ: How Do You Evaluate ∫x²√(1-x²) dx Using Trig Substitution?
What does the notation "W8.3.6" mean in the given expression?
The notation "W8.3.6" refers to the specific problem or exercise number in a mathematics or physics textbook or course material. It is used to identify and differentiate between different problems and exercises.
What is the meaning of "int" in the given expression?
The term "int" in this expression stands for "integral" and indicates that the given expression is to be integrated, or solved using the rules of integration, in order to find the value of the expression.
What is the significance of "x^2" and "sqrt(1-x^2)" in the given expression?
The term "x^2" represents the variable x raised to the power of 2, while "sqrt(1-x^2)" represents the square root of the expression (1-x^2). These terms are commonly found in mathematical expressions and are used to denote the relationship between different variables and functions.
What is the purpose of the "dx" at the end of the given expression?
The "dx" at the end of the expression indicates the variable with respect to which the integration is being performed. In this case, it represents the infinitesimal change in the variable x, which is necessary for solving the integral.
Can you explain the significance of the given expression in real-world applications?
The given expression may have various real-world applications, depending on the context in which it is used. In general, it can be used to calculate the area under a curve or the volume of a solid shape, both of which have practical applications in fields such as engineering, physics, and economics.
