How Do You Find AC/AB Given Tan Ratios in a Triangle?
  • MHB
  • Thread starter anemone
  • Tags
    2017
In summary, the Triangle Ratio Problem involves finding the ratio of the lengths of the sides of a triangle, specifically with a given tangent ratio of 1:2:3 for the angles. To find the value of AC/AB, the tangent ratio formula is used. The steps to solving this problem are identifying the given information, setting up equations, solving for the lengths of the opposite sides, and using those values to find the ratio. This problem has practical applications in various fields and can be solved using other methods, such as using sine and cosine ratios or the Pythagorean theorem, but the most efficient method is using the tangent ratio formula.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
In a triangle $ABC$, $\tan A:\tan B: \tan C=1:2:3$. Find $\dfrac{AC}{AB}$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution::)
1. greg1313
2. kaliprasad
Solution from greg1313:
Using the triple tangent identity
$$\tan A+\tan B+\tan C=\tan A\tan B\tan C$$
and the given ratios we have
$$6\tan A=6\tan^3A\Rightarrow\tan A=1$$
Now we construct a triangle with base $\overline{AB}$ and an altitude from $C$ to $\overline{AB}$ at $P$.
WLOG, let $\overline{AP}=\overline{CP}=1$. Then, to form a tangent of $2$ at $B$, let $\overline{BP}=\frac12$.
We will now verify that $\tan C=3$.
Using the Pythagorean theorem with $\overline{AB}=\frac32$, $\overline{AC}=\sqrt2$ and $\overline{BC}=\frac{\sqrt5}{2}$,
$$\frac54-x^2=\frac94-(\sqrt2-x)^2\Rightarrow x=\frac{\sqrt2}{4}$$
where $x$ is the distance between the foot of an altitude from $B$ to $\overline{AC}$ and $C$.
Again with Pythagoras, the altitude from $B$ is $\frac{3\sqrt2}{4}$ and the tangent at $C$ is indeed $3$.
As $\overline{AC}=\sqrt2$ and $\overline{AB}=\frac32$, the desired ratio is $\frac{2\sqrt2}{3}$.
FAQ: How Do You Find AC/AB Given Tan Ratios in a Triangle?
What is the Triangle Ratio Problem and how does it relate to Tan Ratios?
The Triangle Ratio Problem is a mathematical problem that involves finding the ratio of the lengths of the sides of a triangle. In this specific problem, we are given a ratio of 1:2:3 for the tangent of the angles of the triangle. This means that for each angle, the tangent of that angle is equal to 1/2, 2/3, and 1/3 of the length of the opposite side, respectively.
How do you find the value of AC/AB in the Triangle Ratio Problem?
To find the value of AC/AB, we need to use the tangent ratio formula, which is tan(angle) = opposite/adjacent. In this case, we are given that the tangent of angle A is 1/2, the tangent of angle B is 2/3, and the tangent of angle C is 1/3. We can set up the following equations: tan(A) = 1/2, tan(B) = 2/3, and tan(C) = 1/3. We can then solve for the lengths of the opposite sides for each angle and use those values to find the ratio of AC/AB.
What are the steps to solving the Triangle Ratio Problem?
The steps to solving the Triangle Ratio Problem are as follows:
  1. Identify the given information (tangent ratios) for each angle.
  2. Set up equations using the tangent ratio formula.
  3. Solve for the lengths of the opposite sides for each angle.
  4. Use the lengths of the opposite sides to find the ratio of AC/AB.
What is the practical application of the Triangle Ratio Problem?
The Triangle Ratio Problem has many practical applications in fields such as engineering, architecture, and physics. It can be used to calculate the lengths of unknown sides in a triangle, which is useful in designing structures, analyzing forces, and determining measurements in real-world scenarios.
Are there any other methods to solve the Triangle Ratio Problem?
Yes, there are other methods to solve the Triangle Ratio Problem. One method is to use the sine and cosine ratios instead of the tangent ratio. Another method is to use the Pythagorean theorem to find the lengths of the sides of the triangle and then use those values to find the ratio of AC/AB. However, the tangent ratio method is the most straightforward and efficient way to solve this problem.
