How Do You Find Multiple Solutions for Trigonometric Equations?
  • MHB
  • Thread starter bsmithysmith
In summary, the student is having difficulty understanding how to find the solutions to Sin(Ø)=0.8 and Cos(Ø)=-.55. They are also having trouble understanding the identity sin(\pi-\theta)=sin(\theta). To help them, the student uses a similar technique for the remaining problems.
bsmithysmith
23
I have a quiz on Friday and I'm not understanding one part of the section;
find all the solutions for \(\displaystyle sin(Ø)=0.8\)
and I'm not understanding how to find the other solution. This may be an easier one, but there's also:\(\displaystyle Sin(Ø)=-.58\)
\(\displaystyle Cos(Ø)=-.55\)
\(\displaystyle Cos(Ø)=.71\)Need help finding two solutions for each!
Mathematics news on Phys.org
For $\sin(\theta)=0.8$, draw a unit circle, and then draw the line $y=0.8$. Now, from the center of the unit circle, draw two rays, one to each point of intersection between the circle and the line. The angle subtended by each ray and the positive $x$-axis in the counter-clockwise direction are your two solutions, given that we are looking for solutions in:
\(\displaystyle 0\le\theta<2\pi\)
For the first quadrant angle, use you calculator to find an approximation for:
\(\displaystyle \theta=\sin^{-1}(0.8)\)
Now, can you see how to use this value to determine the second quadrant solution? It has to do with the identity:
\(\displaystyle \sin(\pi-\theta)=\sin(\theta)\)
From your drawing, can you "see" how this identity has to be true?
SWEET! Helped a bunch! Thank You!
For the remaining problems use a similar technique, except where you have the cosine function, use a vertical line instead of a horizontal line for the intersections to help you visualize where the solution(s) are. :D
As a scientist, my advice would be to use the unit circle and trigonometric identities to find the solutions for sin(Ø)=0.8. The unit circle is a useful tool for understanding the relationship between sine, cosine, and other trigonometric functions. You can also use the inverse sine function (arcsine) to find the solutions.
For sin(Ø)=0.8, the solutions are Ø=53.13° and Ø=126.87°. This can be found by using the inverse sine function on a calculator or by using the unit circle and remembering that the sine function is positive in the first and second quadrants.
For the second set of equations, you can use the Pythagorean identity (sin^2Ø+cos^2Ø=1) to find the missing values. For example, for sin(Ø)=-0.58, you can square both sides and then subtract from 1 to find cos^2Ø=0.65. Taking the square root of both sides, you get cos(Ø)=±0.81. Similarly, for cos(Ø)=-0.55, you can use the same method to find sin(Ø)=±0.83. For cos(Ø)=0.71, you can use the inverse cosine function to find the solutions Ø=44.42° and Ø=315.58°.
In general, it is helpful to use the unit circle and trigonometric identities to solve for trigonometric equations. Practice using these tools and you will become more comfortable finding solutions for different equations. Good luck on your quiz!
FAQ: How Do You Find Multiple Solutions for Trigonometric Equations?
What is the definition of sinØ?
SinØ, also known as the sine of angle Ø, is a mathematical function that represents the ratio of the length of the side opposite to an angle in a right triangle to the length of the hypotenuse. It is commonly used in trigonometry and geometry.
How do you find the solutions of sinØ?
To find the solutions of sinØ, you can use a scientific calculator or a trigonometric table. Simply input the value of the angle Ø in degrees or radians and press the "sin" button on the calculator or look up the corresponding value in the table. You can also use the sine function in a programming language such as Java or Python to find the solutions.
What is the range of values for sinØ?
The range of values for sinØ is between -1 and 1. This means that the values of sinØ can never be less than -1 or greater than 1. Values close to 0 represent angles close to 0 degrees or 180 degrees, while values close to 1 or -1 represent angles close to 90 degrees or 270 degrees.
How is sinØ used in real life?
SinØ has many practical applications in fields such as physics, engineering, and navigation. It is used to calculate the height of buildings and structures, determine the trajectory of projectiles, and measure distances and angles in surveying and mapping. It is also used in the development of computer graphics and animation.
Are there any other trigonometric functions related to sinØ?
Yes, there are two other primary trigonometric functions related to sinØ - cosine (cosØ) and tangent (tanØ). Cosine represents the ratio of the adjacent side to the hypotenuse, while tangent represents the ratio of the opposite side to the adjacent side. These functions are often used together with sinØ in solving mathematical problems and in real-world applications.
