How Do You Find Pressure Distribution In A Porous Material?
In summary, the conversation discusses deriving a single equation for the pressure distribution in a porous material using Darcy's law and another appropriate relationship. The equation should be stated in terms of generic operators and allow for the variation of permeability with position. The participants attempt to solve the problem using different approaches, such as assuming steady flow and circular geometry, but realize that a more general solution is needed. The conversation ends with a suggestion to use the divergence theorem to solve for a control volume of arbitrary geometry.
Pchang38
Using Darcy’s law, plus another appropriate relationship, derive a
single equation for the pressure distribution in a porous material. Your equation should be stated in
terms of generic operators (i.e. without assuming any specific coordinate system) and allow for the
fact that the permeability K may vary with position, although you can assume that μ is constant.
Darcy's Law: μ = -K/μ ∇ρ
Where the fluid velocity vector and the pressure are denoted by μ and p, respectively, K is known as the
permeability (which is a property only of the porous material), and μ is the flowing fluid’s dynamic
viscosity.
I attempted to create a modified equation using darcy's and navier-stokes but can't seem to put all the pieces together. Can anyone point me in the right direction?
Do a differential mass balance on a control volume.
Chet
Chet
Hey, thanks for the reply. This is what I have done so far:
We know, Darcy's law: u' = -k/u*grad(P)
So, my thought process is:
1.) We assume steady flow and flow in one direction (linear).
2.) Using the relationship that fluid velocity (u') = Q/A
3.) we get, Q = -kA/u * grad(P)
4.) We know that the shape is circular, so A (cross sectional area) = 2piRH, where R is radius, where H is the height
5.) We know that grad(P) = dP/dR, (only in the radial direction)
5.) so, Q = -k2piR/u * (dP/dR)
6.) now, Separate the variables and integrate from R = Ro to some generic location R:
-> integral(dR/R) from Ro to R = integral(-k2piH/uQ * dP) from Po to P
-> ln(Ro/R) = -2kpiH/uQ * (P-Po)
-> P(R) = Po-uQ/2piKH*(ln(R/Ro)) Final eqn
This equation shows that Pressure varies logarithmically and can be used to find pressure differences.
Does this make sense and seem reasonable? Does it also show that the permeability K may vary with position?
This makes sense specifically for the case of radial flow. But, I'm pretty sure they are looking for something more general than this. Think about the problem in 2D flow.
No. The problem says that K is a function of R, so the equation is not integrated correctly.
What they are looking for is a second order partial differential equation in 2 or more dimensions, involving spatial gradients of pressure, and also involving K. Take a differential control volume between x and x + Δx, and y and y + Δy, with flow through the 4 boundaries of the control volume.
Chet
Chet
Hey, Chet I got some feed back and this is what my TA said:
I would not suggest that approach. Your assumptions are more applicable for a cylinder rather than a sphere, and also ignore the 'no coordinate system' requirement. A different relationship to couple with Darcy's law will probably yield a more appropriate answer. Also, since there is no coordinate system, integration is unnecessary in this problem.
Maybe we were both over-thinking? What do you make of this Chet? I am pretty lost now haha
Who says that the geometry is circular? I never said that. You were the one who assumed circular geometry. All I said was that what you had done applies exclusively to that limited type of geometry, and that what they are looking for is something more general.
Have you learned about the divergence theorem in your courses yet? Do you know how to apply that to a control volume of arbitrary geometry?
Chet
Chet
I do not believe we have covered the divergence theorem yet. But I am somewhat familiar with it. But i believe the theorem requires integration, but the problem I am trying to solve does not
Suppose you have a closed fixed control volume, such that the total amount of fluid within the control volume remains constant. If dS represents a differential element of surface area on the surface of the control volume and ##\vec{n}## represents a unit outwardly directed normal to the surface at the location of dS, what is the rate of fluid flow out of the control volume through the surface element dS (if the seepage velocity is ##\vec{u}##)?
Chet
Are you familiar with the fact that, if the flow is incompressible, the divergence of the velocity vector is equal to zero?
Chet
Related to How Do You Find Pressure Distribution In A Porous Material?
1. How do you measure pressure distribution in a porous material?
To measure pressure distribution in a porous material, a common method is to use a pressure sensor or transducer. The sensor is placed at various points on the surface of the material and the readings are recorded to create a pressure map. Other methods include using a pressure mat or pressure-sensitive film.
2. What factors affect pressure distribution in a porous material?
The main factors that affect pressure distribution in a porous material include the material's porosity, permeability, and thickness. Other factors such as the type of fluid flowing through the material and the velocity of flow can also impact the pressure distribution.
3. Can pressure distribution in a porous material vary over time?
Yes, pressure distribution in a porous material can vary over time. This can be due to changes in the flow rate, temperature, or other environmental factors. It is important to consider these variations when studying pressure distribution in porous materials.
4. How does pressure distribution affect the performance of a porous material?
Pressure distribution plays a crucial role in the performance of a porous material. In applications such as filtration or fluid flow, an uneven pressure distribution can lead to uneven flow and reduced efficiency. It is important to analyze and optimize pressure distribution to ensure optimal performance of the material.
5. Can mathematical models be used to predict pressure distribution in a porous material?
Yes, mathematical models can be used to predict pressure distribution in a porous material. These models take into account factors such as porosity, permeability, and fluid properties to estimate the pressure distribution. However, experimental validation is often necessary to confirm the accuracy of these models.
