How do you find the image of the function?
In summary, the image of the function f : Z*N -> R ; f(a,b)= a/b is the set of rational numbers (Q). This can be proven by showing that every rational number can be written as a ratio of two integers, and that every pair of integers represents a rational number through the function f.
WannaBe
What is the image of the function f : Z*N -> R ; f(a,b)= a/b?
I know the answer is Q (rational numbers) but I don't know how to find it.
Mathematics news on Phys.org
You surely know that any rational number is the ratio of two integers.
Note that any rational can be written as an integer divided by a positive integer.
Here let \(\displaystyle \mathbb{N}=\mathbb{Z}^+\).
Technically, you don't "find the image" of a function, you find the image of a set by a function: the image of set A, by function f, is [tex]\{ y| y= f(x), x\in A\}[/tex].
As Plato said, the set of rational numbers is defined as the set of all fractions, [tex]\frac{a}{b}[/tex] with a any integer, b any positive integer (taking the denominator from the positive integers let's us assign the sign of the fraction to the numerator and voids division by 0).
Now, if y is any rational number, there exist integer, m, and positive integer, n, such that y= m/n. That is precisely f(m, n) so every rational number is in the image.
Conversely, for any pair, (m, n), m an integer, n a positive integer, f(m,n)= m/n is a rational number so the image is precisely the set of rational numbers.
(This function is NOT "one-to-one", f(2, 4)= f(1, 2), but that is not relevant to this problem.)
FAQ: How do you find the image of the function?
What is the image of a function?
The image of a function is the set containing all the output values that result from plugging in every possible input value. In other words, it is the range of the function.
How do you determine the image of a function?
To determine the image of a function, you need to plug in different input values and observe the corresponding output values. This can be done by creating a table of values or by graphing the function and looking at the range of the graph.
Can a function have an infinite image?
Yes, a function can have an infinite image if the range of the function is not limited. This can happen when the function has a vertical asymptote or when it is a linear function with a non-zero slope.
What is the difference between the domain and the image of a function?
The domain of a function is the set of all possible input values, while the image is the set of all possible output values. In other words, the domain represents the independent variable and the image represents the dependent variable.
How do you find the image of a composite function?
To find the image of a composite function, you need to first find the image of the inner function, and then use that set of values as the domain for the outer function. In other words, the image of a composite function is the image of the inner function mapped onto the outer function.
